drive shaft bolts torque specs
BLK05GT said:
The V8 and V6 are both torqued to 76 lb/ft.
Incorrect.
he asked what the shaft to pinion flange bolt specs are, not the trans output shaft to driveshaft.
Pinion flange to shaft consant velocity joint 41 ft/lb
Shaft flange to trans output shaft flange 76 ft/lb
I've replaced too many gas tanks on those things to have that memorizied.....
