  • 1994 - 1995 Specific Tech
driveline vibration
  • Thread starter Thread starter GTS5150
  • Start date Start date May 7, 2004
G
GTS5150
18
jville nc coby ny
May 7, 2004
  • May 7, 2004
got a 95 gts with 5 spd i got a nasty vibe in the drivetrain but not sure where its coming from. it happens aroound 50-70 mph and again at like 90-whatever. im gonna get motor and tranny mounts and a new clutch this weekend .but and info will hepl thanks
slytherin
702
northeast ohio
May 7, 2004
  • May 7, 2004
ive got bad vibe issues as we speak but mine me may be unrelated to yours,(lowering kit&new tranny combo most likely the culprit) but i would say check your d/s to see if it threw a weight, also check your tires&wheels maybe they threw a weight. check your universals and if your car sat all winter like mine you may have some flat spots in your tires.
94Blue302GT
704
Chicago
May 7, 2004
  • May 7, 2004
check your harmonic balancer!!!! it's one of the infamous problems on our cars. They just get plain old worn out. It's a cheap fix to do, and shouldn't take you more than an hour with a couple of hand tools. Check it out, i thought my driveshaft was screwed up, but it wasn't, just a balancer.
G
GTS5150
18
jville nc coby ny
May 9, 2004
  • May 9, 2004
ill check those
yeah was thinking it might be harmonic damper as i should change it as im sure that will lead to very short engine life.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Fox 4 Cyl to V8 Swap Info Thread
  • Matt01
  • Jul 12, 2021
14K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 9, 2023
Robinson
R
Drivetrain Crazy vibration: need some help!
  • 91GTstroked
  • Jul 16, 2019
2K
Fox 5.0 Mustang Tech Apr 7, 2020
91GTstroked
