  • SN95 4.6L Mustang Tech
Driver side door problem
  • Thread starter Thread starter Timin
  • Start date Start date Jul 29, 2004
T
Timin
207
Houston
Jul 29, 2004
  • Jul 29, 2004
I noticed that the door wasn't sealing the way it had been recently. If I didn't give it more force than normal, the door would not shut all the way. I tried adjusting the little lever in the door and I ended up moving it the wrong direction(upwards). I have yet been able to pry it back the other direction to the way it used to be. There are 3 allen wrench bolts around the lever in the door as well if that helps direct where I am talking about.
I was wondering if I can correct what I have done? I have been unsuccessful trying to get it back to where it was.
-Karl
T
TripleBlk
312
Cape Canaveral FL
Jul 29, 2004
  • Jul 29, 2004
Mine's getting balky , too. I understand the "door open" pin switches are in that lever area, and they are a PITA to remove and reinstall. How is the action of the lever when you use the key manually ? Have the parts been lubricated ? You may have to get a manual to get the right procedure. So here's a bump for ya.
J
Adjustment of driver front door
  • JJHstang
  • Feb 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Mar 2, 2025
89ripper
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
