  • SN95 4.6L Mustang Tech
Driver Side window wont go up.
  • Thread starter Thread starter Mr GT 02
  • Start date Start date Apr 15, 2006
1 of 2 Next Last
Mr GT 02
548
Peabody, MA
Apr 15, 2006
  • Apr 15, 2006
I believe a fuse is blown. everytime I push the button for the driver side window to go up..it doesnt and all I can hear is a click type noise coming from the fuse box located by the pedals....
I looked under there and see multible fuses..but I cant figure out which fuse needs to be replaced as they are not marked.. does anyone know which number fuse the driver side window is?
tomustang
Psychotic Member
3,434
McLean Hospital
Apr 15, 2006
  • Apr 15, 2006
the list of fuzes will be in the owners manual
BlackenedSVT
1,841
New Jersey
Apr 15, 2006
  • Apr 15, 2006
I think the fuses and what they operate is also written on the back of the fuse box, no? If not, Tom's right, it will be in the manual.
If you dont have the manual for some reason, let me know, and i'll try and take a picture of the fuse and fuse box for you from my car.
I had this same problem a few months ago. The driver side window would not go UP at all. It went down in the morning, and would not go back up for 2 days. I had to leave the car in the garage over the weekend in fear of someone looting it over night. And when i jumped back in the car monday morning, the driver side window went up. So the problem fixed itself. ... still dont know what the hell caused this.. maybe an intermitent short somewhere? Beats me, but it works now, and i dont need to buy anything for it
Mr GT 02
548
Peabody, MA
Apr 15, 2006
  • Apr 15, 2006
Welp.....
I got back from pepboys...installed the new Fuse for the power windows..and its still doing the same thing..I had a feeling it wasnt gonna be the fuse cause..wouldnt BOTH windows not work? ....so now im shyt outa luck and imma have to bring the car to Ford so they can figure this out.
damnit
BlackenedSVT
1,841
New Jersey
Apr 15, 2006
  • Apr 15, 2006
Mr GT 02 said:
Welp.....
damnit
That clicking you probably hear is a relay. try checking and replacing the relay.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Apr 15, 2006
  • Apr 15, 2006
if it clicks the relay is working is either your window motor or regulator that took a chit
DropTopPony
Noob Slayer
2,570
south jersey
Apr 15, 2006
  • Apr 15, 2006
bang on the door while pressing the switch to raise it. don't bang on it to hard as to break the window. It may be stuck.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 15, 2006
  • Apr 15, 2006
could be corroded connections on the button
blacknblue2002
159
Va Beach, Va
Apr 15, 2006
  • Apr 15, 2006
Slam the door shut....I've had the same problem three times....two times I had the window motor replaced under warranty...on the second time the guy at the Ford place said it happens all the time...he slammed the door....it worked after that...but they still replaced it under warranty....third time it happened....I slammed the door and it worked fine
Reactions: merc123 and K mustang
BlackenedSVT
1,841
New Jersey
Apr 15, 2006
#10
  • Apr 15, 2006
  • #10
Gotta love mustangs
Sounds like slamming the door should be a TSB
Mr GT 02
548
Peabody, MA
Apr 15, 2006
#11
  • Apr 15, 2006
  • #11
right now the window is all the way down. When I push the buttom for it to go up...it does nothing and there is no click noise comming from the fuses under the steering colum. But when I push the button for the down position..I then hear the click noise from the fuse box under the steering colum. Its definetly not the fuse cause I replaced it with a new one and is still doing the same thing......
hope the bill is not to high once ford fixes the issue.
N
n0v8or
604
Rhode Island
Apr 15, 2006
#12
  • Apr 15, 2006
  • #12
The click you hear whan pressing the Down switch is probably the "one touch down" relay located within the Generic Electronics Module (GEM). The GEM is mounted next to the fuse panel under the dash. The relay should not operate for window Up, so seems to be operating properly.
Your problem is most likely the switch or GEM. If the motor were bad, it should not run the windown down either.
If you hold your hand on the edge of the glass while operating the switch, can you feel anything . . . like a faint vibration or slight movement of the glass?
CRZYHRSGT
240
5.7 miles north of THE Ohio State University
Apr 15, 2006
#13
  • Apr 15, 2006
  • #13
Same problem about a week ago...window would intermittently go down and not back up, sometimes not even down. Even had the banging of the door scenerio. Long story short...dropped $130 at my favorite Ford parts counter and got a new motor/regulator assembly (not including core charge). A little over an hour and a nasty sharp metal cut on my hand later the problem is fixed. They stocked like 5 of them so it must be a tad bit of a problem...
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 16, 2006
#14
  • Apr 16, 2006
  • #14
it's probally the motor, but remember if you end up testing the circuits, polarity reverses on this circuit, thats how the motor runs backwards to move the window down.
urban96
3,464
Syracuse, NY
Apr 16, 2006
#15
  • Apr 16, 2006
  • #15
to see if its a switch/relay you could run +12V and -12v right to the motor and if it moves you know the motor is fine
G
Ghost001
398
California
Apr 16, 2006
#16
  • Apr 16, 2006
  • #16
Is the window all the way down?
My driver side window got stuck in the all-the-way-down position.
I did a search, and found that most people solve the problem by removing the door inside panel and hitting the window motor with a hammer.
That did the trick for me.
Since then, I never let either of my windows go all the way down.
Mike97gt
it doe snot
10,633
Apr 16, 2006
#17
  • Apr 16, 2006
  • #17
lettting it go to the bottom did not cause that. a bad power window motor caused it. when you tap the motor you improve the conection and move the brushes a little to get off of a bad spot. sooner or later that motor will give out for good.
K
K mustang
#18
  • Sep 5, 2015
  • #18
I don't know if it will work or not but slamming the door over and over does work 80% of the time on these cars. The motors get stuck. If slamming the door doesn't work take the door panel off and tap the motor with a hammer. That usually does the trick.
Prodigy
92
21
18
Sep 6, 2015
#19
  • Sep 6, 2015
  • #19
Ok, so i have had many problems with the ford window setup. First take the switches and soak in wd40. While the switches are soaking, take the door panel off. Once door panel off Pell away plastic. Take the connector off where it comes from window motor, take a 12v battery and touch the leads. Reversing polarity will reverse motor direction. If motor works, is not your issue. Once switches are good and soaked take out blow out excess. Put a switch in the switch block, with motor hooked back up, if it does the same thing is the blue gem box, that controls instant up or down.
I had the same problem, but mine got stuck down, rift before a 3 day down poor. So i manually, with battery, raised the window. Also only one switched worked. After cleaning they all work. Just had to replace the module gem. ALSO if advise as to slamming the door, just tap the door panel in bottom left hand corner ( this is where module is on inside of door panel)
merc123
420
North GA
May 18, 2016
#20
  • May 18, 2016
  • #20
Thank you! Third slam took care of this! First time in 13 years I've had this problem and a 10 year old thread solved it!
1 of 2 Next Last
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
1989 Passenger side electric window issue
  • Sanchez_005150
  • Jul 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
Rust under side window weatherstrip
  • swe13
  • Jun 5, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 5, 2025
swe13
W
2012 Base Convertible Driver Side Power Window Will Not Work
  • wmmihail
  • May 25, 2024
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech May 25, 2024
J
For Sale 2003 mustang GT
  • jimted79
  • Mar 22, 2025
SN95 Mustangs For Sale (1994-04) Mar 22, 2025
jimted79
J
