Driver's Side Tire Rubbing Control Arm On Full Turn
  • Thread starter Thread starter Ant85
  • Start date Start date Dec 23, 2013
Ant85
99
9
Richmond, VA
Dec 23, 2013
  • Dec 23, 2013
I went out looking under my car because I suspected I had another coolant leak. I happened to glance at the sidewall of the tire and you could see it was shiny like it was rubbing on something. I looked a little more and on one side of the control arm(if the wheels were pointed all the way to the left) there was a shiny spot on the control arm. The tire size is correct, car is not lowered, nothing is bent(drives true, alignment is good). Any ideas?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Dec 23, 2013
  • Dec 23, 2013
what year car, what size tires.
Sometimes when you put oversie tires on, especially in the earlier year foxes, you get tire rub. If you are certain nothing is bent, worn or tweaked, a simple fix could be a set of rack limiters. You simply loosen the boot on the inner tie rod to the rack. You will see the factory rack limiters. Just add one or two more until the tire stops rubbing.
Reactions: Ant85 and cdurbin
Ant85
99
9
Richmond, VA
Dec 23, 2013
  • Dec 23, 2013
The car is a '92, but I don't have the 16" SSP wheels. I have 15" 10 hole wheels from an earlier year Mustang. 225/60/15 are what's on there. I didn't think that would make a difference on a later model year would it?
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Dec 23, 2013
  • Dec 23, 2013
nah, you shouldn't be having any rubbing issues with stock tires on 10 holes. Best is to jack it up and turn the wheel all the way in an out and see where and why it's rubbing. Something aint right.
Reactions: Ant85
Ant85
99
9
Richmond, VA
Dec 23, 2013
  • Dec 23, 2013
I'll do that tomorrow and post an update. Thanks
Ant85
99
9
Richmond, VA
Dec 24, 2013
  • Dec 24, 2013
Got a chance to jack it up. I don't see any weird reason why this is doing it. I also heard that Ford had a recall back in the day for rubbing issues like I am describing? I could not find any information about this on the internet. It came from someone who worked at a Ford dealer in the early 90s and remember this being an issue.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Dec 25, 2013
  • Dec 25, 2013
I know Ford started adding Rack Limiters and also changed the fenders and fender extensions around 1991.
MFE92
1,094
373
124
Phoenix
Dec 26, 2013
  • Dec 26, 2013
If your car is a 92 and it's rubbing at full lock, I suspect it's had an '87-89 steering rack installed at some point, OR the correct rack's steering limiters are chewed up. If the car is straight and everything's centered, get some steering rack travel limiters for a few bucks, remove the retaining strap on the inboard edge of the rack boot, pop the boot off, and snap another limiter over the inboard end of the tie rod. Reattach the boot and clamp and call it a day.
Ant85
99
9
Richmond, VA
Dec 26, 2013
  • Dec 26, 2013
I will have to take a look at that. Thanks.
H
QA1 coilovers rubbing/hitting control arms
  • hassler
  • Sep 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
hassler
H
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
