Driveshaft mayhem cont. with pics
mytight95
2,605
Dothan,Al
i went and took the exhaust the rest of the way off of the car today and also pulled the tranny, look like i have a bent shifter top, a bent output shaft, a busted extension housing and two of the mounting ears off of the case itself have been broken off. I have one flowmaster with a hole and the others have dents. pipes are mashed flat and the h is mashed pretty badly as well. and the driveshaft is a joke.
i will try and attach some pics
Here are some more
heres the broken ears probably barely can tell from the pic
and the mangled exhaust
kinda disheartening, my parts list as it stand is driveshaft, whole new t-5 case, mid-pipe, and possiblyl a catback. Already bought the lakewood driveshaft loop
yeah that thing caused some serious havoc under my car
jason
Interesting, I wonder exactly how it happened. I figured the front dropped, but it looks like that's not what happened. I guess the back dropped, and then the front slid out, hit the ground, and then boom. Weird.
Dave
Ouch.... :bang: That really does suck...
Any luck with a replacement tranny or parts?? Makes you wonder if its even worth rebuilding it??? She took a beating for sure... :(
well form what i can tell, the back came out and hit the pavement, and bounced around a little (or a lot) and then bound somehow bent and then flopped around some more because i heard it flopping for a few seconds, when i had the car towed the driveshaft was still in the tranny but dislodged from the rear and the u-joint was still in the rear as well
wassup andy, yeah i don't know about parts, i have the tranny tore down the mainshaft is bent the shifter forks shaft(slider) is bent and the mainshaft lost a few teeth. The plan is to swap all the gears into another case, this tranny was a HD tranny out of a cobra so i plan on keeping this setup if possible.
jason
p.s. anyone with spare parts let me know
