Driveshaft safety loop questions
  • Thread starter Thread starter Mike92GT
  • Start date Start date Jan 28, 2006
M
Mike92GT
583
Florida
Jan 28, 2006
  • Jan 28, 2006
At what point am I required to have a safety loop in my car?
I already have a Ford Racing (HPM) loop, I just have to install it. I've been putting it off 'cause it looks like a PITA. Any tips on installing one? Or pictures? I tried searching already...
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 28, 2006
  • Jan 28, 2006
Well Mike - if you've ever seen what happens when a car loses a driveshaft at the strip ----
For me it's not when someone else requires it -- I want one for my own safety and to minimize the possibility of damage to the car. And you've got PLENTY enough torque to do some damage. Crawl under there - it won't be as bad as you think. Installing it will be a helluva lot easier than repairing the damage if you lose one at speed. Not to mention the potential for personal injury...
Sermon over. Stepping down off of soapbox.
red302
881
Peru, IL
Jan 28, 2006
  • Jan 28, 2006
I believe the NHRA rule book states 12.99 and quicker to require a drive shaft safety loop. They're very easy to install. I have a Lakewood and is bolted to the floor with 4 bolts.
M
Mike92GT
583
Florida
Jan 28, 2006
  • Jan 28, 2006
Thanks guys. I haven't raced my car yet, otherwise it would have been on there a long time ago. It's at the top of my to-do list. I just want to make sure I get it right the first time so I don't end up with a bunch of extra holes in my floor.
mustangsally93
281
Omaha,NE
Jan 29, 2006
  • Jan 29, 2006
you I guys got pics? I got to get one but dont' know where to put it and what it looks like. I was told at 500 rwhp is went you should get one.
Black1987Stang
1,422
Jersey Shore
Jan 29, 2006
  • Jan 29, 2006
Anybody got pics of one installed? Do u have to drill ur own holes and use nuts and bolts or theres already a place for it to bolt in? Thanks
mustangsally93
281
Omaha,NE
Jan 29, 2006
  • Jan 29, 2006
yea need more input, johny 5 need more input
393Bird
244
Clarksville Tennessee
Jan 29, 2006
  • Jan 29, 2006
NHRA Rules state:
Drive shaft loop 13.99 (8.59) For drag slicks only
Drive shaft loop 13.00 (8.14) For “street” or DOT tires
2.4 DRIVELINE ( Drive shaft loop 6 inches from the front U Joint)
On any car in which the driver sits over or in back of the rearend center section, a suitable protective shield of .120-inch (3 mm) minimum thickness steel plate must be installed for those units with universal joints securely mounted to the rearend center section and the bellhousing adapter. Where possible, couplers are recommended in place of U-joints. For straight couplers, the minimum requirement is .063-inch (1.6 mm) aluminium which must contain an inspection cover for removal and inspection of the coupler, securely mounted to the rearend center section and the bellhousing adapter, or as noted in Class Requirements. In place of a crossmember, in the vicinity of the front universal joint, all cars in competition using open driveshafts, must have a retainer loop 360-degrees of enclosure, 1/4-inch (6.35 mm) minimum thickness and 2-inches (5.1 cm) wide, or 7/8-inch (22.2 mm) x .065-inch (1.65 mm) welded steel tubing, securely mounted and located within "6-inches" (15.2 cm) of the front universal joint f or support of the driveshaft in event of U-joint failure. Recommended the loop be round rather than oblong to minimize loading on loop. Open drivelines passing any part of the driver's body must be completely enclosed in 1/8-inch (3.2 mm) minimum thickness steel plate, securely mounted to the frame or frame structure.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 29, 2006
  • Jan 29, 2006
Yup Mike - just mock up/measure/mark 2 or 3 times before you cut/drill/weld.
We used to have a saying in the pipeline business -- "I don't know what's wrong -- I've cut it three times and it's still too short..."
04sleeper
2,674
14
89
Dallas, TX
Jan 29, 2006
#10
  • Jan 29, 2006
  • #10
This is what could happen if you loose your driveshaft....
http://videos.streetfire.net/Player.aspx?fileid=41DC920E-59E3-49A5-920C-411A2DE0A784&t=top&kw=5&p=40
D
Daggar
3,902
#11
  • Jan 29, 2006
  • #11
Holy Crap!
I would imagine that he had a loop but that it was installed on the wrong end?
04sleeper
2,674
14
89
Dallas, TX
Jan 29, 2006
#12
  • Jan 29, 2006
  • #12
Daggar said:
Holy Crap!
Not sure, but if you look closely you can see it come out.
Something wasn't right.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 29, 2006
#13
  • Jan 29, 2006
  • #13
one more vote for the lakewood drive shaft loop. it is easy to install.
mustangsally93
281
Omaha,NE
Jan 29, 2006
#14
  • Jan 29, 2006
  • #14
yea just spent the 32 dollars for one from summitracing.com. yea not happening to me
RYC CUKR
1,437
Orlando
Jan 29, 2006
#15
  • Jan 29, 2006
  • #15
Thats gonna leave a mark.
R
rowdie- stang
172
augusta ga
Jan 29, 2006
#16
  • Jan 29, 2006
  • #16
To me it looks like the torque boxes ripped out of the car which pulled the drive shaft out of the trans.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
A
Electrical New O2 sensor harness has no jumpers (91/93)…
  • afjLX
  • Dec 11, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
afjLX
A
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
