Drivetrain Bucking and Lurching.... ???
  • Thread starter Thread starter Katmandu
  • Start date Start date Apr 27, 2007
Katmandu
302
Troy, Ohio
Apr 27, 2007
  • Apr 27, 2007
When driving my 91GT (w/T5) at slow speeds, the drivetrain occasionally starts lurching and bucking. This typically happens around 5-10MPH in while in 2nd gear and around 10-15MPH in 3rd gear.
The U-joints are good and tight as are the transmission/motor mounts. A local mechanic blames low gears (3.73s) that are in it.
What could be causing this ??
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 27, 2007
  • Apr 27, 2007
You need to downshift into a lower gear. The engine is trying to stall because there is too much load on it for the RPM's that it is turning.
302RollinHard
Columbus, OH
Apr 27, 2007
  • Apr 27, 2007
also if you have a moderate cam in your car, the bucking problem will be magnified.
Katmandu
302
Troy, Ohio
Apr 27, 2007
  • Apr 27, 2007
I "think" that is what the mechanic was trying to tell me.
I should have mentioned that there is a clanking noise coming from the rearend area when this is going on.
Is this "normal" then ?????
302RollinHard
Columbus, OH
Apr 27, 2007
  • Apr 27, 2007
fairly normal. There is some lash built into the rear end. That is probably your clanking noise. However, if it is really loud, I would have it looked at.
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Apr 27, 2007
  • Apr 27, 2007
mine does the same thing...same gears...ect. Just have to keep the rpms up, which is a pain in traffic/stop and go situations
NKau
1,346
Jefferson, WI
Apr 27, 2007
  • Apr 27, 2007
The bucking is normal, but again, just keep the rpms up at low speeds, and it won't be a problem. The clanking is normal; your rearend, and even tranny probably have enough 'looseness' in them to do this. Just make sure the u-joints are indeed OK.
Sicarius428
2,085
Apr 27, 2007
  • Apr 27, 2007
The clanking is your drivetrain slop most likely. It is normal because there will always be a bit of play from the engine to the rear wheels. It's loading up the gears and letting off over and over so it is really amplified.
Kevin
Flavadave4
1,044
21
49
Utica, NY
Apr 27, 2007
  • Apr 27, 2007
Mine does the same if you let out the clutch and go with no throttle, give it the gas and its gone!
Katmandu
302
Troy, Ohio
Apr 27, 2007
#10
  • Apr 27, 2007
  • #10
I'm used to driving around in my Dodge Ram w/Cummins Turbo Diesel. That thing can pull a house down at 1000 RPMs! The low-end torque is ungodly!
My Stang is mainly a weekend fair weather cruiser, so I guess I gotta change low RPM driving techniques then!
Here's a pic of my Cummins Turbo Diesel Ram....
http://www.katmanduonline.net/pics/98_Ram/
Black1987Stang
1,422
Jersey Shore
Apr 27, 2007
#11
  • Apr 27, 2007
  • #11
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
