Dropped a wrench in transmission?
MadMatt5oh
441
St Paul, MN
Hey guys during my Pro 5.0 install I managed to drop a wrench down the shifter hole! Is it putting my car in any danger if I dont find it? Or is it most likey on the ground? My car is in about 6 inches of snow and its dark so I cant tell :(
funny ...:rlaugh: thats a joke right?
If you really did get it in the hole, DON'T DRIVE IT! More than likely, unless it was a very very small wrench, it is on the ground. I can't see a wrench getting in that little hole...
Don't drive it until the wrench is in your hand.
Are you talking about the place where the shifter mounts to the tranny?
If so then you better find the wrench asap, If you managed to get a wrench into the tranny from there than you better tear you tranny completely apart until you find the wrench went....Good Luck
If it's on the tranny casing it's fine. I've lost tons of sockets that get stuck on the little lip on the K-member. Once in a while when i do oil changes i still find a couple stuck up there :)
right on they work, they also have a flexable wire thing (lol sorry so vague) but you squeeze one end and it works like a claw (3 little claws) to grab stuff but it goes just about anywhere maybe sears or autozone might have em. Good luck
When I removed my shifter, there was nowhere that I can see a wrench going. It was just a hole with a bottom, you can't see the gears or anything. More than likely it's on the ground, as it can't get "inside" the tranny. If it did fall into the hole, it'd be right there staring you in the face.
um, it really has no where to go. If you cant see it, then its on the ground
most likely it's on the ground. it won't hurt anything being stuck somewhere unless you're driving down the highway and it falls out and hits someones windshield.
i lost a socket bolt while installing my long tubes one time. i thought the darn thing fell into the starter hole into the bell housing, because it didn't fall to the ground. that drove me crazy for hours. i finally found it. darn thing fell where all the primary tubes join the collector and stuck in there.
