dropped piston on floor
  • Thread starter Thread starter worknon10s
  • Start date Start date Jun 26, 2005
W
worknon10s
601
Westminster
Jun 26, 2005
  • Jun 26, 2005
tearing down the motor i missed and let one pistons from my 460 hit the floor. its a stock 71 piston. I plan on reusing them for this budget build up project. it looks ok, whats the chance I cracked it? do you think its ok to use?
ExplodingGopher
517
The mistake on the lake (Ohio)
Jun 26, 2005
  • Jun 26, 2005
If this is a performance oriented 460, then i would toss all those stockers on the floor and get some new ones, my keith black pistons for my 466 cost $293 from summit. If its a stock rebuild, then new stock replacements are relatively cheap from federal mogul.
T
TheUser
1,859
Springfield, MO
Jun 25, 2006
  • Jun 25, 2006
I dropped my #1 piston on the floor too. I pushed it and it came out easier than expected and hit the the cement floor. I inspected it w/ a magnifing glass and can't see any cracks, only the small dent on the top edge of the piston. The dent doesn't seem to cause the piston the be "out of round" on the edges, however it did push some metal up on top (a slight hump). It will still fit in the cyclinder. I don't want to buy another one if I don't have to.
This is the best pic I can get due to the light shining on the rounded piston:
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jun 25, 2006
  • Jun 25, 2006
i did the same thing with my piston on my 302 i rebuilt, it fell from the engine stand and knock it a bit flat on the edge. it fit fine and engine turns great.
you can file it down or something, but if it fits and and doesnt scar the cyl wall, then it should be fine. Hell if it can survive a simple 3 foot fall, then how will it hold up against thousands of explosions per minuite??
it'll be fine.
Reactions: jonathanrea123
88 Fox GT
1,674
Iowa
Jun 25, 2006
  • Jun 25, 2006
it'll be fine.
Because dropping it on the floor is not the same as the explosions inside the chamber. It could have landed in any direction whereas the combustion is evenly spread across the top of the piston only. If you really want to reuse the stockers, check them over as much as possible and use a magnifying glass to check for any cracks or anything.
T
TheUser
1,859
Springfield, MO
Jun 25, 2006
  • Jun 25, 2006
ah they're not stockers, they're forged speed pro's .030 over from the last rebuild. I'll ask the machine shop what they think. Thanks.
stang89bidges
Advanced Member
Mar 14, 2014
727
144
74
Fort Worth Texas
Feb 9, 2015
  • Feb 9, 2015
So what ever happened on your dropped piston? I know this is an old post but maybe I will get lucky and your still hanging around ;-)
I did the same thing. Hoping I can reuse the piston.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 9, 2015
  • Feb 9, 2015
Reactions: A5literMan, madspeed and stang89bidges
stang89bidges
Advanced Member
Mar 14, 2014
727
144
74
Fort Worth Texas
Feb 9, 2015
  • Feb 9, 2015
It's the only post on whole site that discusses a dropped piston actually.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Feb 9, 2015
#10
  • Feb 9, 2015
  • #10
any dent or ding in that portion of the piston wll create a hot spot likely causing premature failure
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
