  • 1994 - 1995 Specific Tech
DSS306 or 331!!!!
  • Thread starter Thread starter SN95FREAK
  • Start date Start date Jul 31, 2008
First Prev 2 of 2
SN95FREAK
9
North Carolina
Aug 1, 2008
#21
  • Aug 1, 2008
  • #21
Hey Thanks everyone!! You all have helped me out alot in my decision, by the way how much is gas on average, Im in ramadi iraq right now so I'm a little disconnected.
BlackVert
5,589
9
98
Bethesda, MD
Aug 1, 2008
#22
  • Aug 1, 2008
  • #22
GasBuddy.com - Find Low Gas Prices in the USA and Canada
in DC it is a little over $4.00 per gal right now
Yobi1Kanobi
559
#23
  • Aug 1, 2008
  • #23
gas mileage really shouldnt be the determining factor tho. you want economy buy a civic.
FWIW...with the proper rings 347s will not burn oil even with an interjecting wrist pin. the 347s that burnt oil had very low tension oil rings and wore very quickly..they did this initialy to squeeze out a little more HP.
Pokageek
2,767
MA, USA
Aug 1, 2008
#24
  • Aug 1, 2008
  • #24
I totally agree. The difference between 331 and 306 aint much anyway. My 414 is going 240 miles on a tank easy. I will check again..
Killercanary
The car that set the bar.
Altoona, PA
Aug 1, 2008
#25
  • Aug 1, 2008
  • #25
I'd say if you have to get a new shortblock, get the bigger cubes even if the supporting H/C/I are on the small side for it. Sure, it won't be on par with cars with the properly matched HCI for their strokers, but it'll make more TQ and be a better platform to build from than a 306. I went with a 331 for one reason and one reason only, the turbo kit I have had a relatively small turbo for it and the 331 would work well with it, and with the T76 I have since upgraded to. It was a compromise because I didn't know what turbo I'd use when I built the stroker. If I had to do it all over again I wouldn't have bought the turbo and I'd have a higher compression 363ci NA setup.
SN95FREAK
9
North Carolina
Aug 1, 2008
#26
  • Aug 1, 2008
  • #26
I updated my original thread to give a little more info. on my plans. Let me know what yall think .Thanks everyone
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 1, 2008
#27
  • Aug 1, 2008
  • #27
nmcgrawj said:
Sidebar: its amazing to me how the 347 "oil issues" rumors still exist. I read about that when i first joined this site and guys proved it otherwise. Is that EVER going to die?!?!?!?
I know for a fact it will not go away within the next decade.
The oil burning is still a fact, because it still happens.
It will always happen when there is incorrect oil ringland pieces used and/or engine assemblers.
To say that all 347 will not burn oil is an inaccurate statement as well.
A solid ringland is still better than a cut ringland for wrist pin clearance for pure longevity. Luckily, there are a few top-notch engine builders out there to close the gap.
blksn955.o
3,263
st.louis mo 314
Aug 1, 2008
#28
  • Aug 1, 2008
  • #28
Since your looking to get new heads/cam/intake...get the 331. Get a custom cam from one of the big 3 custom guys and a good tune should get you to pass tx smog and run more than enough to blow up the AODE. Might want to look at an edlb./TFS/Holley intake over the gt40 if you go 185's.
BTW, thanks for serving...Wifes cousin is in the Marine's currently. Lucky bastage is stationed in HI. Take care.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 1, 2008
#29
  • Aug 1, 2008
  • #29
I'm in the Dallas/Fort Worth part of Texas and its around 3.65 for the low
grade 87 stuff
If you got a hot rod that needs the 93 grade good juice like mine
Recently ... it can be had for just under 4 bux
Hey ... I just might have to get that old red fellow out of the garage
so me and mama can cruise around town a bit
Grady
First Prev 2 of 2
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
P
4 Hole Bosch Injectors max HP and Tune -4.6 PI
  • Png1978
  • Jul 23, 2022
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech Aug 10, 2022
Chipss36
F
1993 Cobra flooding
  • FireFoxCobra_SVT93
  • May 20, 2022
6K
Fox 5.0 Mustang Tech Mar 11, 2023
nickyb
T
Engine 306 to 331
  • Treachery
  • Jul 1, 2020
2K
Fox 5.0 Mustang Tech Jul 2, 2020
nickyb
J
Need Help: 95 Mustang GT Engine Rebuild
  • jurban421
  • Jul 25, 2021
  • Other Auto Tech
2K
Other Auto Tech Jul 25, 2021
jurban421
J
