  • SN95 4.6L Mustang Tech
DTC Help
  • Thread starter Thread starter brent_cosenza
  • Start date Start date Oct 9, 2006
brent_cosenza
70
Georgia
Oct 9, 2006
  • Oct 9, 2006
I need help with these codes for my 02 mustang gt.
DTC 1131 & 1151
BooWFO
991
Louisville, KY
Oct 10, 2006
  • Oct 10, 2006
P1131 Lack Of HO2S11 Switch - Sensor Indicates Lean
1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
Appears your running lean.
I've seen header/manifold leaks cause a lean code, also I've heard sometimes when you go to LT's you get a lean code.
Also kinda odd but my buddies cobra threw lean codes when the o2 sensor's went out.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Oct 10, 2006
  • Oct 10, 2006
check for vacumm leaks and if you can see live data watch the voltage of both sensors, your maf and the fuel trims. the sensors would have not gone bad at the same time, somthing is causing that car to run lean.
merc123
420
North GA
Oct 10, 2006
  • Oct 10, 2006
Make sure that your airbox hoses are all connected. I can't remember the exact code I got but my CAI tube disconnected from the TB.
sgarlic
3,085
Oct 12, 2006
  • Oct 12, 2006
My buddy just threw the exact same 2 codes after splashing through a huge puddle of water. Just erased the code and it never came back.
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
K
Procharger Stage 2 - 2013 Mustang GT Minor Hiccups
  • KHills5058
  • Oct 9, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 9, 2025
KHills5058
K
K
2013 Mustang GT Procharger Stage 2 Kit Issues
  • KHills5058
  • Oct 9, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 10, 2025
KHills5058
K
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
