  • SN95 4.6L Mustang Tech
DTC P1505 Help...
  • Thread starter Thread starter Mo94Cougar
  • Start date Start date Jul 1, 2006
M
Mo94Cougar
  • Jul 1, 2006
Out of the blue my 4.6 will not run at closed throttle idle. Replaced IAC, TPS, CCRM, and ICM. Cannot find any vacuum leaks, I can fool it with a feeler gauge between idle stop screw and throttle return and runs fine. I used the actron OBDII and gives me a P1505 at times. I replaced the CCRM because I do not think the fan low speed is operative when it is fooled, and the idle correction when the air conditioning compressor is operating does not actuate. Any ideas?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 1, 2006
  • Jul 1, 2006
The only time I've had this happen is a loose vac hose or the bad IAC. Maybe someone else will ahve more...bump for ya.
M
Mo94Cougar
  • Jul 2, 2006
Thank you for your reply and help. If anyone else has any info, it is welcome.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 2, 2006
  • Jul 2, 2006
Maybe check the fuel filter or fuel pump...
  • Gulftown980x
  • Jul 29, 2026
squeak93
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
