Dumb exhaust question (hangers)
1hot5.0
1,615
Surprise, Arizona
Can you use the hangers from the stock h-pipe on an aftermarket mid-pipe? I just noticed today that they bolt on, and my Bassani X (used) just happens to have no hangers on it. Any replies would be greatly appreciated. Thanks!
Do you have the right X pipe? Why isn't there any hangers on it (did the previous owner cut it off or something?)?
Edit: For reference mine had the ones that were on the stock pipe (the crossmember with 2 bolt holes, and the one by the smog line with a single bolt hole), but I only used the big one.
I just spent several hours installing a piece of CRAP Magnaflow catted x pipe. :mad: :mad: :mad: It did not have the hangers on it per say. It should have two holes drilled in a supporting piece of metal. The hanger has two bolts already in it that will fit in these corresponding holes. You will see once you get under the car.
I had an awful hard time getting mine to fit. I had to strain my guts to try and spread apart the pipes that match up to the headers. I ended up having to use a hydraulic jack to assist in getting the nuts on the header studs. I will never buy another Magnaflow product again. I thought I was getting a quality piece. :bang: :bang:
Yea there is two holes where it looks like the hangers could bolt into place (they are right next to the cross member). The hole for the smog tube I already bolted the smog tube to...
I guess I'll give it a shot some time. Thanks guys! :nice:
Sounds like you're good to go. Have fun.
HoofnIt: so how is it? Did the sound at least ease your temper some when you started it up? :D I'd always heard Magnaflow was good quality, but apparently they're slipping. :nonono: Didn't you get a new one sent (and it was the same crap)?
Yea, this was the SECOND one they sent me. I measured the width of the header flanges and it was no different than the 1st one. I wish I knew what it sounded like but I am no quite through swapping the HCI. If I get my new pushrods in a few days then it should be up and running by this weekend. I'm keeping my fingers crossed.
