Dumb Question, but I'll ask just to make sure.
evilfitz
31
Wisconsin
Is it safe to jack up the back of car with the floor jack on the rear diff?
My floor jack is more then big enough for the weight but I don't want to damage my rear-end. The front is already up (again), so I want to get the rear up all at once to minimize the chance of the car being off balance and sliding while its going up.
Thanks, I figured it probably was. I have to replace my leaf springs and etc. So I'll have to put my stands right behind my sub-frame connectors plus one more somewhere further back if I find a good spot out of my way just to be on the safe side.
Ideal jack stand locations for rear spring job:
Jack the car up by the rear, place 2 stands under the rear subframe just north of the spring bolt in area, then lower the rear to 0 load (no weight on the springs and not pushing up on the springs either) and place stands under it. This will keep the rear in the right spot while you man handle the springs out.
be REAL careful if you're using a floor jack to lift the rear up when the front is already on jackstands. I say this because a floor jack doesnt lift the rear straight up, it moves it slighty forward or backward as it comes up. Nothing in the world is creepier than seeing a car rock forward tilting the jackstands. dont ask me how i know. :D
I made some front wheel blocks out of some spare 2x4 and 2x6. Put the front wheels in the blocks and then jack up the back of the car...it won't go anywhere. I have already bet my life on it....more than once.
Let me know if you want a picture of my wheel blocks.
