  • 1994 - 1995 Specific Tech
dumb question
  • Thread starter Thread starter tlee_20
  • Start date Start date Oct 15, 2006
T
tlee_20
48
Rogersville, TN
Oct 15, 2006
  • Oct 15, 2006
well i am getting ready to buy a new intake and i am gonna go ahead and buy the stuff i need for my turbo setup. will a trick flow R box intake fit stock heads?? its the same lower as the R just the box top. on summits site it has a note saying will only fit trick flow R heads.. just want to make sure. i need an intake now just to run through march and theres no need in buying another street manifold since i am gonna go with the r box in 5 months..
T
tlee_20
48
Rogersville, TN
Oct 15, 2006
  • Oct 15, 2006
so nobody knows if the trick flow r intake will fit stock heads?? all the "r" lowers are the same so if anyone is running an "r" on e7's let me know..
parchisi
519
New Mexico
Oct 16, 2006
  • Oct 16, 2006
I ran the R lower on ported AFR 185's and I just made sure that the intake ports matched the head ports. I had to do a little grinding on the intake ports to match it up. The E7 ports are probably smaller though, so you shouldn't have to do so much work.
T
tlee_20
48
Rogersville, TN
Oct 16, 2006
  • Oct 16, 2006
well if im not worried about restriction i wont have to do any modifying will i? i know they're not gonna be gasket matched like the r heads but will the intake work?? not for max efficiency but just work at all???
Methodical
1,192
11
59
Clinton, MD
Oct 16, 2006
  • Oct 16, 2006
Delete
thegreentaco
40
Sacramento
Oct 16, 2006
  • Oct 16, 2006
I'm running the "R" lower on e7's, fit perfectly
T
tlee_20
48
Rogersville, TN
Oct 16, 2006
  • Oct 16, 2006
thank you.. thats all i was wondering. i know the actual intake will hurt my low end torque but i have to have it when i do my swap in a few months and theres no sense in buying an intake now to run till march and have to fork out another 650 on an r box. btw, i took a chance and ordered my r box this morning. i was hoping it would bolt up fine. thanks again guys
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
