  • SN95 4.6L Mustang Tech
dumbest question in stangnet history
  • Thread starter Thread starter GTFTW
  • Start date Start date Jun 14, 2010
G
GTFTW
51
  • Jun 14, 2010
i really feel so embarrassed for asking this, but here it goes.....
is there a way to pull trouble codes without a handheld tuner or taking it to an auto parts store?
please take it easy on me lol
I
ItsStock02
492
Westland, MI
Jun 14, 2010
  • Jun 14, 2010
****in noob god dammit!!!!
lol im just playing. I know with obd 1 cars you can use a paper clip to just two terminals together and the CEL light will flash your code.
I just checked and you can do the same with obd 2
Locate the 16-pin data link connector. Connect the jump wire to terminals 4 and 9 of the connector. Turn the key to the "On" position without starting the engine.
Step 2
Watch the "Check Engine" light. This light will begin to flash in specific patterns to indicate a 1- or 2-digit Diagnostic Trouble Code. The flashes will be long for the first digit, short for the second digit and blank if the digit is 0.
Step 3
Record all the codes given. The "Check Engine" light will display the codes in sequence and then keep repeating them in order. Refer to your repair manual to check for the meaning of the codes.
Read more: How to Read OBD2 Codes | eHow.com How to Read OBD2 Codes | eHow.com
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jun 14, 2010
  • Jun 14, 2010
Yup, go to Ebay and get yourself a OBD2 USB port cord 14.00, it goes to your car and lap top, then go the Easy OBD2 web site and down load there software for free. The free software will allow you to see fuel trims, lean/rich ratios, and among other things, oh, it will allow you to clear and read codes but not interpret the codes you will need to look them up in a manual or the internet. For a better program its maybe 20 bucks.
http://cgi.ebay.com/ebaymotors/CAN-...Z230487573622QQptZMotorsQ5fAutomotiveQ5fTools
fshawn50
161
Houston, TX.
Jun 14, 2010
  • Jun 14, 2010
why not take it to an autoparts store? unless undriveable?
They usually will check it for free and give you code # ?
Then jump online an look it up?
Or you can always come back on here an post up so another member could look it up?
slygray1
14
Belfair,Wa
Jun 14, 2010
  • Jun 14, 2010
I didn't think that was a dumb question.
Tim2002GT
635
Tulsa, Oklahoma
Jun 14, 2010
  • Jun 14, 2010
Nah, not a dumb question at all. Depending on what year your car is, this may work... Mustangworld HEC Instrument Cluster Diagnostics
And btw, Welcome to :SNSign:
T
TripleBlk
312
Cape Canaveral FL
Jun 15, 2010
  • Jun 15, 2010
Yes.
I bought a BR OBDII box and hooked it to an antique IBM Thinkpad. I can view just about everything going on with my 'Stang..
The car manufacturers probably squealed like piglets, but one good thing the Feds made them do was to adhere to the OBD II protocols, so that we civilians could have some insight. Otherwise, we would have been locked out of the proprietary secret protocols, and forced to give up big bucks to the dealer franchise for decoding.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 15, 2010
  • Jun 15, 2010
that only gives codes for the cluster.. it will not give pcm or any body module codes
newer car Radios and EATC control heads have the same thing, a diag mode for DTC's related to the radio or EATC
Tim2002GT
635
Tulsa, Oklahoma
Jun 15, 2010
  • Jun 15, 2010
Whoops! My bad!
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
Jun 15, 2010
#10
  • Jun 15, 2010
  • #10
TripleBlk said:
Yes.
You can say that again, some of these foreign car makers have made it so that you must take the car to there dealerships to get the computers read. Kinda' putting the private mechanic buisness owners out of buisness b/c the computers they need to read these DTC and modules cost a small forturne.
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
J
Reduced power in 1st and 2nd gear
  • jimted79
  • Feb 25, 2025
SN95 4.6L Mustang Tech Feb 25, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
