Locate the 16-pin data link connector. Connect the jump wire to terminals 4 and 9 of the connector. Turn the key to the "On" position without starting the engine.
Step 2
Watch the "Check Engine" light. This light will begin to flash in specific patterns to indicate a 1- or 2-digit Diagnostic Trouble Code. The flashes will be long for the first digit, short for the second digit and blank if the digit is 0.
Step 3
Record all the codes given. The "Check Engine" light will display the codes in sequence and then keep repeating them in order. Refer to your repair manual to check for the meaning of the codes.
Read more: How to Read OBD2 Codes | eHow.com
