50mustang001 said:Dynamat is soooo overrated. Save yourself a ton of money and go to home depot and go to the roofing section. There you will see these rolls sitting on the shelf. They're yellow with green writing. It's just about the same stuff as dynamat. I use it in my car is it works really well. I have it in the rear hatch, under back seat and on both door panels. It's $13 for a 16x6 roll. The stuff sticks real well and doesn't smell at all. Get that stuff instead of dynamat and get the same results.
jtkz13 said:![]()
Results = Lots less exhaust & tire drone, dont hear the suspension squeaks, and the doors close with a nice thud, not clunk, with the windows up. The stuff I used is FatMat and I bought 100sq feet off Ebay for $100+shipping. I still have some leftover. Its worth it if you do alot of driving, but it'll take a couple days for the smell (kinda tarry) to go away. Adds maybe 50lbs, if that.
Is that the actual name of the stuff at Home Depot, or does it have a specific name? I was gonna get dynamat for my door panels but it'll cost too much, so maybe I'll just get this stuff.JokerWylde said:Peel n' Seal (the stuff at Home Depot),
tribune said:is that silicon you have around your door speaker?
JokerWylde said:Sometimes you find it under that name, although it might be called something like "gutter repair tape". It can be hard to find sometimes, and I do believe that only certain stores actually carry the stuff. If you don't find it there, you could give Lowe's a try, or Menard's, if you have one around. To be honest with you, it probably won't do you any good to ask anyone at the store, since they probably won't know what you're talking about. Just gotta head to the roofing section and search.
The stuff I found came in two varieties: one was aluminum faced, like Dynamat Extreme, and the other had a white face; either one would work.
