DYNO--80mm C & L MAF vs. ProM 87mm and the winner is......
TacBear
1,243
Jasper, AL
ProM 87 mm MAF :banana:
The graph is hard to see so here goes:
Mods are in Sig.
The only change was the MAF!
C & L = 236.3 rwhp and 280.5 rwtq--I never could get my car to Idle right with this on it. It would go back and forth between 550 rpm and 900 rpm at idle every time I would come to a stop.
ProM 87mm MAF = 241.4 rwhp and 289.1 rwtq-- Idles like stock A/F ratio is almost straight from 3000 rpm to 5800. A gain of 5.1 rwhp @ 8.6 rwtq at peak and almost that much from 2200 rpm to 5800 rpm. I think I will stick with the ProM MAF :banana:
mogs01gt said:
Did the car run more lean?
Was that dyno run right after the ProM install?
Was there a cool down period?
Did you reset the ECU?
Nick
> Look at the Dyno sheet, with the ProM the A/F ratio was almost flat from 3000 (12.6) to 5800 (12.1). The C @ L was all over the place, 3000(14.0)-3500(12.5)-4000(12.1)-5000(11.5)-5500(10.7)
>I changed to the ProM, cooled the engine down and reset the ECU before the 2nd pull!
Thanks for the good info. Not much tech on here lately, so threads like this are a breath of fresh air. I rode the C&L bandwagon for a year or more, but I finally came off of some money and went with the Pro-M 95mm setup. No dyno data, but I had the same driveability issues with the C&L. The Pro-M has been like factory stock in comparison.
EDIT-
where are the T/A and pulleys in the sig? With those you'd surely cross the 250 rwhp mark and maybe get close to the 300 rwtq mark.
EDIT-
I am still trying to decide wether to Supercharge or not :shrug: If I stay N/A I'll have Pullies, T/A, headers,cams, gears, Tune and maybe P & P heads by the end of the year :nice:
Hopefully 290+ rwhp and 315+ rwtq :flag:
Get some L/T's :D. Mine go in on the 23rd. I hear ya TacBear, I dont know if Im going to stay NA or go S/C. Ive got pullies, cai, flows welded in, get my l/t's, mid pipe, and spec stage II put in on the 23rd, then Ill go with a TB/Plenum combo to top it off. Id like to have 290-300rwhp, I guess I will see, there are few believers on here lol. It probably wont happen, but if I can do it then I will be all :banana: If I cant then I have one hell of a set up to strap a kenne bell onto after I get forged internals :nice:
Back on topic, my one concern is I thought you had to send back the Pro M if you change injectors. Cant you just do a chip with the C&L and compensate for injector size, or can you do this with both? For some reason I was under the impression that the only way you can change the calibration of a Pro M is to send it back to the manufactuor (sp)
My ProM is calibrated for 19# Injectors and the C and L was supposedly calibrated for 19# Injectors. Luckily I had someone buy the C and L right after I dynoed my car!
P.S.: ProM makes a device that allows you to program your own MAF.
