dyno number 331
  • Thread starter Thread starter 93stang burden
  • Start date Start date May 22, 2010
First Prev 2 of 2
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
May 24, 2010
#21
  • May 24, 2010
  • #21
COMP Cams - Cam Details
i think your cam should look somewhat like that, i have this exact cam in my car and the drivabilitly is good, it dosent buck at low rpm's, and makes great power everywhere
KamiKaziDK
555
Mesa, Az
May 25, 2010
#22
  • May 25, 2010
  • #22
There's a guy in the 94/95 forum with a 331 running 185cc patriot heads, x cam, gt40 tubular, 24 lb injectors, STOCK maf, 70mm tb, that pulled 321hp and 374 ft/lbs with 12.7 a/f ratio. So on a combo that isn't as good, he made 15 more hp and 23 ft/lbs more torque.....there's something wrong with the tune or something,
Dino Dino Bambino
1,672
89
79
Cyprus
May 25, 2010
#23
  • May 25, 2010
  • #23
93stang burden said:
i am al ittle diappointed with these numbers i think the intake is killing me?
The torque is pretty good but your 331 has a bad case of asthma and the primary cause is the Cobra intake. You have a 210cfm intake which is choking off your 260cfm heads. You could go for a Holley Systemax II instead. It'll definitely add more HP at the top end with minimal TQ loss lower down. Add a 75mm TB, 80mm MAF, retune the chip, and you should be golden.
Tanus
847
A to the Z
May 25, 2010
#24
  • May 25, 2010
  • #24
+1, holley intake and a bigger cam would definitely jump those numbers big time
from6to8
There's suction so I used that end O_O
1,904
143
94
Feb 1, 2024
#25
  • Feb 1, 2024
  • #25
tell what you think
what numbers lol?
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,946
5,818
213
Feb 1, 2024
#26
  • Feb 1, 2024
  • #26
My 331 made 423hp on the engine dyno. Ported 170 heads and ported systemax intake. Who knows if the numbers were inflated. It was done by the engine builder....who also used cheap gaskets. It's turbo now and not dynoed.
from6to8
1,904
143
94
Feb 1, 2024
#27
  • Feb 1, 2024
  • #27
Rw or fw?
Mustang5L5
Mod Dude
Feb 18, 2001
43,327
18,052
224
Massachusetts
Feb 1, 2024
#28
  • Feb 1, 2024
  • #28
OP hasn't been back to the site since 2013.
from6to8
1,904
143
94
Feb 1, 2024
#29
  • Feb 1, 2024
  • #29
What's the general rule of thumb I know I'm going to do a 331 stop block and I have a few intakes that I would like to run and a few heads that I'm thinking about. Do you pick the heads first and then match the cam?
Mustang5L5
Mod Dude
Feb 18, 2001
43,327
18,052
224
Massachusetts
Feb 1, 2024
#30
  • Feb 1, 2024
  • #30
Cam last. Pick your heads, displacement, intake and then figure out how you are going to drive the combo. Race car? Daily cruiser? Cam selection will change. Ideally you wait for the end because if you have your heart set on a 331 and then something changes, that would affect your cam selection. Leave it to the end and then.
Reactions: AeroCoupe and from6to8
R
Rcdgl
5 Year Member
Feb 19, 2018
313
168
63
Feb 6, 2024
#31
  • Feb 6, 2024
  • #31
My carbed 331 with afr 185 heads made just over 400/400 on an engine dyno. Comp roller, eddy performer rpm, 600 cfm vac secondary holley.
from6to8
1,904
143
94
Feb 6, 2024
#32
  • Feb 6, 2024
  • #32
Damn so only around 320 to the wheels
AeroCoupe
6,144
4,233
183
Claremore, OK
Feb 6, 2024
#33
  • Feb 6, 2024
  • #33
So did it meet your expectations or ???
R
Rcdgl
5 Year Member
Feb 19, 2018
313
168
63
Feb 6, 2024
#34
  • Feb 6, 2024
  • #34
The 331 in the above post has run a high 740 eighth mile, na. So I am happy with it. Been down for flying and now rust repair for two years.
First Prev 2 of 2
Melling M-10687 Green Spring
  • AeroCoupe
  • Aug 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
AeroCoupe
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
