  • SN95 4.6L Mustang Tech
Dyno numbers in! - SCT = thumbs up!
  • Thread starter Thread starter LizardKing 2002
  • Start date Start date May 25, 2004
  • 3
  • 4
First Prev 3 of 4 Next Last
gnat
144
#41
  • May 26, 2004
  • #41
quite possibly, my mustang dyno sheet has me down for 3620lbs
LizardKing 2002
100
Ottawa, Ontario
May 26, 2004
#42
  • May 26, 2004
  • #42
He put the weight in front of me right there on the computer... WTF! Let me call him.
Steeda Boy
135
Embrun, Ontario, Canada
May 26, 2004
#43
  • May 26, 2004
  • #43
Ok, I think you guys need to relax and give this guys a chance. I've seen this guy run his stang. I for 1 beleive what he's saying because he's far from a bull****er. I used to drive a 01 GT Convertible, and we used to race all the time. I can tell you that this guy is a good driver and he wouldn't lie about this stuff. Infact I would bet anything that stock for stock he'd beat most of you on the 1/4. He's an experienced driver, he's driven stangs since I've known him.
First of all his list of mods are good for his #'s
Prochambers are f***ing amazing. I used to run 14.1's all day until I got this peice. After getting this peice I ran a constant 13'8 ! You do the math !
SCT Tunning are by far the best out their right now. I see that most people calling BS on his case don't even have the SCT. I for 1 know that a good tune will be like night and day.
All I'm trying to say is try to understand why he's getting these #'s instead of calling BS when you don't even know the car or the guy.
Just my 2 cents.
Steeda,
Stangt00
50
#44
  • May 26, 2004
  • #44
LizardKing 2002 said:
Most 1/4 mile calculators would say I need 270WHP to get a 13.57 ...
Bill Putnam was pulling 12.5's with 260ish RWHP and 4.30's. The weight was dropped down some, but it was still a daily driver.
Before the major work, with all bolt ons: off road prochamber, pullies, K&N, M/A, T/B, Welded in Flowmasters, DYNO TUNED CHIP and 3.73's, I pulled 252/294 RW and ran a 13.29 with drag radials.
01BlkGT
1,015
ATX
May 26, 2004
#45
  • May 26, 2004
  • #45
To me the numbers seem a lil off. I had full exhaust, pullies, t/a (15*), and my car put down 265 rwhp. Also, if your car is putting those rwhp numbers down, and you have someone on here backing up that you are a good driver, then something isnt adding up with your et trap mph. With 265rwhp (dynojet), on street tires, I was able to get 103-105 mph traps consistently. You should be at least trapping 103, but with the rwhp you were talking about I would think you should be trapping above 105. You have any other time slips?
gnat
144
#46
  • May 26, 2004
  • #46
there is a little check box in the mustang dyno that allows them to turn the real world load simulation off and this could be what causes the higher than expected numbers.
kirkyg
3,568
Beaumont, TX
May 26, 2004
#47
  • May 26, 2004
  • #47
Definetly calling BS. Your showing about 20 more rwhp than your numbers should be at best. I would guess your car without any cats would dyno in the 240-242 range.
jmo
kirkyg
zgarske1038
222
Hilton Head Island, South Carolina
May 26, 2004
#48
  • May 26, 2004
  • #48
hmmmm somethin seems fishy
JonJon
4,801
back in Marylands
May 26, 2004
#49
  • May 26, 2004
  • #49
i want to goto that dyno
it's like beau's dyno
LizardKing 2002
100
Ottawa, Ontario
May 26, 2004
#50
  • May 26, 2004
  • #50
jmo
kirkyg
I don't mean to be an ass here. But seeing I gained 8.5WHP with the tune alone. What do you value the pullies and exaust at? 12WHP combined? What does a stock GT dyno at? 220WHP? For some reason I was under the impression most of them started in the 230WHP...
Last question, If ring in a 13.3 at a high 102MPH... what sorta WHP does that seem like?
kirkyg
3,568
Beaumont, TX
May 26, 2004
#51
  • May 26, 2004
  • #51
Um dude im talking about the mods you made a list of above. Obviously with timing adjusted / tuning you will gain another 8-10 hp which would put you at about 250 hp. but no where near 270+
kirkyg
san~man
O-G
A little grass shack on a big lava rock
May 27, 2004
#52
  • May 27, 2004
  • #52
I hate to be the bringer of bad news, but with the mods YOU listed, it's physically impossible to dyno 271 on a Mustang Dyno. Period.
Sorry bro, but someone fugged up. No offense.
LizardKing 2002
100
Ottawa, Ontario
May 27, 2004
#53
  • May 27, 2004
  • #53
Ok. Simple 2 questions.
1. What does a stock mustang usually dyno on a mustang dyno?
2. A 5spd coupe that runs a 13.3 @ 102MPH will have how much HP roughly ... a range, anything?
3. Does my Dyno tech need to take in account the 3.73 gears which don't give a direct 1:1 ratio in fourth?
SAE adjusted, the 271 converts to just over 260WHP... and I know with the mods I listed it is highly improbable.
Stangt00
50
#54
  • May 27, 2004
  • #54
My 5 speed coupe ran 13.29 with 3.73's and drag radials. That was with 252/294 STD at the wheels
YES, the gear ratio needs to be taken into account on the dyno. Correct me if I am wrong, but stock gears will not spool up as quickly as taller gears will. So if the car is pulling really hard and the dyno thinks it has stock gears, its going to post the wrong numbers. Just my guess on how that works, but I know for sure the gears need to be taken into account on the dyno.
Zinc001
410
#55
  • May 27, 2004
  • #55
My 01 dyno'd 187hp & 225tq when it only had a catback. That was on a Mustang dyno set at 3650lbs and 12hp at 50mph.
Last year when I first installed my blower I dynoed my car on both a dynojet and a MD in the same morning. 308hp on the MD and 370on a dynojet. Comes out to 20% difference. So my original pull of 187 would have been about 224hp on a dynojet. That would put you at 325hp on a dynojet, which is why everyone is saying "no way".
Doug
kirkyg
3,568
Beaumont, TX
May 27, 2004
#56
  • May 27, 2004
  • #56
I think you got things backwards. Mustang dyno's read considerably LESS on the dyno. So being that its already ludicrous that you could put out 270 rwhp on a dynojet its twice as unbelievable that you could put out 270 with those few tiny mods on a mustang dyno.
1/4 mile times are not necessary directly correspondent to hp. There are alot of things to take into account mainly involved with suspension/weight transfer and traction. Just say my car runs x in the 1/4 mile gives no indication of rwhp. 3.73's will have a small NEGATIVE (not positive) affect on the dyno. All in all it looks like either the person that dynod your vehicle fudged the numbers to make you feel good or your just out and out lying. Not trying to accuse anyone of anything but thats about the only possibilities.
kirkyg
Zinc001
410
#57
  • May 27, 2004
  • #57
QUOTE]
Yes!!! If he had you set for 3.27's and you have 3.73's. The whole thing will be right out to lunch.
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
May 27, 2004
#58
  • May 27, 2004
  • #58
I’ll probably take some shots for saying this but dynos are really a tuning tool not a “how big is my pecker” meter. LK’s numbers are high no doubt but of all the dynos out there the Mustang Dyno is the easiest to manipulate the numbers with. Not that I think he or anyone else would do this on purpose but if one parameter or setting is done incorrectly then it’s hard to compare numbers from one car to another unless it’s on the same dyno because there can be way too much variance.
I’ve known LK from other boards and he is not one to post up BS just for attention. His old car was fast and backed up the ETs with proof and I don’t doubt he’s truthful here. Best thing he can do is hit the track with the new power and see what it does.
Bill
kirkyg
3,568
Beaumont, TX
May 27, 2004
#59
  • May 27, 2004
  • #59
I didn't know you 'set' anything for gearing on a dynomometer.
kirkyg
StangJonGT
1,329
Seattle
May 27, 2004
#60
  • May 27, 2004
  • #60
Your times are good, LK, for your mods. Your trap speed shows that you are not making 270rwhp, however. My guess would be in the 245-250rwhp range. Don't sweat it, you seem to have a handle on your car either way.
Jon
  • 3
  • 4
Just ordered the BBK 78mm Throttle Intake, getting dyno tuned. Come guess my numbers!
  • georgio440
  • Oct 26, 2009
2K
1996 - 2004 SN95 Mustang -General/Talk- Oct 27, 2009
georgio440
C
thinking of selling moded stang how much??
  • cooper
  • Feb 27, 2007
1996 - 2004 SN95 Mustang -General/Talk- Feb 28, 2007
ADRENLN
T
Up for discussion, SCT dyno day
  • TGJ
  • Oct 21, 2005
  • Regional Forums and Event Information
Regional Forums and Event Information Nov 9, 2005
TGJ
T
Dyno results with Comp Cams thanks to SCT
  • Kurgan
  • Dec 9, 2003
15K
SN95 4.6L Mustang Tech May 30, 2006
lvmustanggt
