Dyno Numbers
1995 5.0
15
Just got back from the dyno. I ended up with 281 hp and 307 ft lbs. i am pretty happy considering whats done to it.
I had one problem, and that was my ignition coils are going bad so anything above 6000 it would miss like crazy but we got that problem solved.
a list of what is done
70 mm tb
90 mm MAS
WMS cold air intake
Steeda Underdrive pullies
160 t-stat
trick flow upper plenum
pi intake
02 pi heads
262 comp cams
comp cam valve springs
o/r bbk h pipe
flow master 40s with dumps
Luke
Nice numbers man! The only iffy thing about your setup is the 160degree T-state. The general concensus is that the 4.6 runs best at its designed operating temperature, ie, using the stock 192degree thermostat. 180 is probably the lowest you'd want to go. Definitely post up a dyno graph
