Dyno Questions
  • Thread starter Thread starter SWYZ721
  • Start date Start date Nov 14, 2004
SWYZ721
208
Ann Arbor, MI
Nov 14, 2004
  • Nov 14, 2004
How come a lot of the dyno's I see in SN member's threads the power drops off, well dyno's in general, always have the power drop off. I mean when you spin the engine, you make power, and the faster you spin the more you make. So theoretically the faster the more power, but why is it that the power drops off, I mean i understand the TQ dropping off due to the mathematics and calculation of HP. so why does the power drop off, cam selection? valve float?
Sorry for the cross posting but I wanted more traffic.
TrickStang37
292
  • Nov 14, 2004
cuz basically the engine is not getting enough air to support the elevated RPM's. needs better airflow.
SWYZ721
208
Ann Arbor, MI
Nov 15, 2004
  • Nov 15, 2004
but as the engine spins faster doesn't it creat more vacuum, and even if it's not getting enough air then wouldn't the power just plataeu and not drop off.
Just debating because I'm looking for more than just the yes/no answer. No arguing.
R
Ray@VSK
355
  • Nov 15, 2004
Cars simply perform best @ certain range, dynos show you where that range is. If that was the case how come you don't have the same plateu as you say @ lower rpms then.. Air, fuel, gears, transmission, computer, etc, etc make the curve, what you ask is like saying how come my car ain't going no faster when I'm @ 6000 rpm as it does @ 5.
SWYZ721
208
Ann Arbor, MI
Nov 16, 2004
  • Nov 16, 2004
Well what I'm saying is CFM=Power, True? Well the faster you spin the engine, the more air the engine breathes, so when dynoing how come the power drops off at the end like usually peak HP and TQ is reached before or around 5.5K, shouldn't the power just keep coming as you rev higher, turbo cars seem to always be gaining power in their dyno, what's the deal, is it the cam?
N
Notched
113
  • Nov 16, 2004
well the car can only suck in so much air/fuel... turbo cars, the faster u spin the motor, the more air is forced into the cylinders, and the computer compensates for this by adding in more fuel. same with a supercharger, except there is only so much air a cylinder can hold, and engine can suck in....
yes it does create more vacuum, but only a certain amount of air/fuel can fit.
i know waht your saying about it just platueing, and not dropping.
ill assume in saying that as the rpms get higher, the combustion of the mixture in the cylinders becomes less, since its being taken in, and spit out much faster, not allowing either a full burn, or wahtnot.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 16, 2004
  • Nov 16, 2004
the cam controls how much air the cylinder gets. The higher the rpm, the less time the valves are open and the ability of the intake/heads to fill the cylinder is reduced - so is power.
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 18, 2026
nickyb
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
Big Posi and Neg wire from Starter to Battery and Alt wires..........
  • from6to8
  • Feb 9, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 9, 2026
AeroCoupe
