Dyno Results are in, Pics - Holley Systemax II Kit :sad:
89' 5L w/ 90,000km
-Holley Systemax Kit II (heads/intake/cam)
-Crane Gold RR's
-BBK Longtube headers, H-pipe, flowmasters
-70mm Holley TB
-75mm C&L MAF w/ 24lb injectors
-lightweight flywheel, alum driveshaft, Tremec tranny
-Electric water pump, electric fan
-Superchip Custom Tuneable chip using a R/T interface
247whp @ 5100RPM
275tq @ 4000RPM
We were on the dyno for 3hrs trying to figure out why the numbers were so low, but ended up nowhere. We ran a test on each cylinder to check for a differential but they were all even.
It falls on it's face after 5200RPM and sounds weird after that point. One weird thing is that the MAF voltage climbed like normal until 5200rpm, and then stopped going up. This is where the power begain to drop hard and a different sound could be heard. We couldn't figure out if the MAF was the problem, or if it's voltage thing was a biproduct of another issue.
We spend 3 hours on the dyno trying to figure it out, but I think this is jus the power that it's going to make. We suspect its that the Holley heads are not the best.
Yesterday I raced my old Mustang (335whp on a dynojet, 102mph trap).
It begain to pull on me a little at about 65mph, but we were even untill then.
Oh, and I'm losing that big tach. It's 2000rpm off anyway.
89' 5L w/ 90,000km
-Crane Gold RR's
-70mm Holley TB
247whp @ 5100RPM
275tq @ 4000RPM
