E-bay intercooler piping?
  • Thread starter Thread starter darkside03gt
  • Start date Start date Jan 28, 2008
D
darkside03gt
851
Sacramento CA
Jan 28, 2008
  • Jan 28, 2008
Just wundering what you guys think about the intercooler pipe kits that are found on E-bay? Iam asking because Iam hoping to put my vortech on in a few months and would like to add a intercooler. It looks like I can do it for less than $400 with a icevex intercooler from superchargersonline. And no i dont want to use a E-bay intercooler mainley because most of them are only rated to around 350hp and I dont like using no-name parts that are important. Please if anyone has first hand experience please chime in. thanks.
BennyBlown2v
1,233
Carmel, INdiana
Jan 28, 2008
  • Jan 28, 2008
I bought a piping kit on ebay - not specific to mustang but just some straights, 90's, 75's, 45's, etc... I used an ebay core too..the pressure drop on it is kinda crappy though, went from 10.5-11psi to with 3.33" pulley to 7.5-8psi after the intercooler I had a big writeup thread on my intercooler experience
http://forums.stangnet.com/showthread.php?t=691858
D
darkside03gt
851
Sacramento CA
Jan 28, 2008
  • Jan 28, 2008
Thanks. but why didnt you mount the intercooler behind the bumper support?
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 28, 2008
  • Jan 28, 2008
some people dont want to cut up the crash bar.
i cut mine and i used an ebay IC the first time also. the pressure drop is terrible. the last time i redid my setup i went to a treadstone IC. it is a better IC with less of a drop.
anyways i have used ebay piping kits both times with no problems. i did get beads welded on the last one b/c i kept blowing the piping apart. i would get some better couplings and t bolt clamps
forum155pl
520
the 509
Jan 28, 2008
  • Jan 28, 2008
they work well for the price.. i recomend after you get all of it fabd up that you take it somewhere and have it beadrolled so you wont blow em apart.. a diesel shop around here beadrolled all of my IC piping ends for $15
BennyBlown2v
1,233
Carmel, INdiana
Jan 28, 2008
  • Jan 28, 2008
I wanted to fully expose the core to the air stream - rather than just half exposed. I cut the foam insert in such a way that it acts like a shroud to push the air into the IC. Also, I didn't want to move the power steering cooler lines, or have them directly sandwiched against the IC. ALSO when mounting the IC behind the crash bar you're going to be putting it closer to the radiator which is going to significantly decrease the effectiveness - while also soaking the intercooler with its radiant heat. Might not be such a big deal on the street, but for open track reasons it seems valid.
Probably a smaller, more expensive core would make more power while being more efficient. I might switch cores if it bugs me enough later
jivepepper
776
Under a Sombrero. in WV.
Jan 29, 2008
  • Jan 29, 2008
Well I used a ebay ic and piping before most, almost 2 years ago. The pressure drop is a little much. But at the same time the iats where incredible low.
There's a kit on ebay now that is made for the new edge mustangs. It has bead rolled pipes better clamps and couplers with a similar intercooler. It's also cheaper than I did mine for.
http://cgi.ebay.com/ebaymotors/Ford...emQQcategoryZ33742QQihZ015QQitemZ250209685508
SilverBullet00
1,150
Wichita, KS
Jan 29, 2008
  • Jan 29, 2008
I am planning on buying all new aluminum tubing for mine and geting it welding into 3 sections. Now I might look at getting a more efficient intercooler as well
ACT sensor in plastic charge pipe
  • 92Rustang
  • Jul 23, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2024
92Rustang
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Progress Thread Project 2nd Chance Pony - Status Update
  • JKWilson61
  • Dec 14, 2019
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2020
JKWilson61
NEW FOX IMPUT/ADVICE
  • Madness7645
  • Jun 22, 2019
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2020
Madness7645
So,...You're gonna take your car to a shop to have it worked on...lets talk.
  • CarMichael Angelo
  • Mar 3, 2019
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 3, 2019
Rdub6
