a trans is a trans, however the gear ratios and stall converter affect the low end feel is up the parts and the tranny itself. for mustangs a t5 will feel like it has much more low end than an AOD, the first gear ratio on most t5s is 3.35 and the ratio in AODs is like 2.80 something i forget exactly.
any aftermarket cam with more duration and less LSA will move the powerband up and a low end loss is felt. the more duration and etc. the higher the powerband goes and the softer the bottom end gets.
the e-cam is pretty mild, its a street cam and you probably couldnt tell a difference in the low end. but if you want to get technical then the e-cam will lose a bit of low end.
