E303 cam
whats specs on that cam
HYDRAULIC ROLLER CAM: 2500 stall, 3.55-3.73 gears,
better heads, intake and fuel system
Camshaft Specs:
Part Number 35-518-8
Engine 1986-1995 Ford
5.0L
Grind Number FW XE274HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.555 0.565
Duration At 0.006 Tappet Lift 274 282
Valve Timing At 0.006
Open Close
Intake 29 65
Exhaust 77 25
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 224 232
Lobe Lift 0.348 0.354
Lobe Separation 112
Can send payment via paypal ASAP if you still have it. I can do other forms of payment too. PM me more info on the cam, pics, and your contact info. You sure it's an E303, correct?
How many miles on the cam?
Thanks
cam
i was told it was f cam but when I took it out of the box it appears to be an e cam to me. It looks like it was double stamped but the e stands out so I am assuming it is an e. That is my personal opinion. It has about 1500 miles and 4 1/8 passes. can send pics of cam if you want them.
