e303 make power with stock heads
  • Thread starter Thread starter ninety1gt
  • Start date Start date Nov 3, 2005
ninety1gt
162
san antonio
Nov 3, 2005
  • Nov 3, 2005
if i install an e303 cam, with my mods, and stock heads will i gain hp/tq????????
1990LXDropTop
430
Western Massachusetts
Nov 3, 2005
  • Nov 3, 2005
LOL this question has been asked too many times... The answer is NO. You will actually loose torque and your stock heads won't flow enough in the upper rpms to benefit with an e-303. The stock cam will work better than an e-cam.
ninety1gt
162
san antonio
Nov 3, 2005
  • Nov 3, 2005
awwwwwwamnit:
V
v8only
2,378
22
49
Nov 3, 2005
  • Nov 3, 2005
damn, you've likely already lost power with your current combo. a 70mm throttle body is way too big for what you're running. FYI, i'm running a gt40 intake, and gt40p heads, and a 70 is too big for that application.
you're on the right road with all your intake and exhaust mods, match that 70mm up with a set of alum heads and a cam. If not, lose the 70mm throttle body for a stocker.
Paul Perreca
1,085
  • Nov 3, 2005
24 # injectors? stock heads??
legalize420
1,541
South Florida
Nov 3, 2005
  • Nov 3, 2005
:Word: im running stock injectors with a 65mm
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 3, 2005
  • Nov 3, 2005
I ran an RPM intake with 70mm TB on my stock motor..ran just as well as it did with a 65mm, you'll be fine with that. Guys will run the Ecam with stock heads, there is a power gain even with the E7 heads, however the #'s won't really justify the work to install the cam. Aftermarket heads allow the cam to shine and work in an enviorment it was designed for.
Paul Perreca
1,085
  • Nov 3, 2005
you can run stock injectors up until you hit like 280 rwhp lol you need aluminum heads, aftmrkt intake, (or ported) and that cam before u make anywhere close to needing 24#ers - it may be holding u back also, seems like your heads are totaly bottlenecking ur power, i bet u've bogged urself down and if u throw a set of heads on there, ur entire system of perf parts will actually be working, and then u'll feel a HUUUUGGGE difference -
V
v8only
2,378
22
49
Nov 3, 2005
  • Nov 3, 2005
good call, missed those. 19#'s are good enough till 300ish. with your current configuration, you're making 250, tops.
Paul Perreca
1,085
#10
  • Nov 3, 2005
  • #10
maybe even a little bit less- the parts though would start working together instead of against eachother when he puts on higher flowing heads- suggested edelbrocks or the two debated ones TFS TW's or AFR 165 or 185's
T
txblackmach1
31
#11
  • Nov 3, 2005
  • #11
well since i was going to post up a similar question. i guess i will just do it here since we are on the subject. i was going to put an e-303 with 1.7 rr on some stock heads. should i just leave the stock cam with the 1.7 rr. i want to keep the stock head for now since there in such good shape. what combo do you guys recomend if its going carb?
N
NUTCASE
187
#12
  • Nov 3, 2005
  • #12
actually, stock cam with a 1.7rr ain't such a bad combo. I've heard of people making good power and drivability with that setup
Sicarius428
2,085
Nov 3, 2005
#13
  • Nov 3, 2005
  • #13
Keep the stock cam. The e cam with 1.7 will probably net less power with the stock heads.
Kevin
ninety1gt
162
san antonio
Nov 3, 2005
#14
  • Nov 3, 2005
  • #14
i guess i'll be saving up for heads
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Nov 3, 2005
#15
  • Nov 3, 2005
  • #15
For cost VS performance don't overlook the iron GT40 heads either...if it's a good running strong package your looking for I'm a huge fan of Thumper heads and when combined with a ford alpha cam you can for WELL under 1000 put togther a damn fine engine package capable of 12 second runs with suspension and tires.
ninety1gt
162
san antonio
Nov 3, 2005
#16
  • Nov 3, 2005
  • #16
yea i read all the info on thumpers website, and pretty much new that power/price are very resonable, probably gonna choose thumpers and e303
Paul Perreca
1,085
#17
  • Nov 3, 2005
  • #17
good choice, that w/ a fresh rebuild should net u the power n reliability you're looking for! How many miles on the motor? May not need rebuild - but usually if u are going as far as tearin heads off, it's a good idea to replace at least all the lifters, and as many gaskets as you can get to !! Good luck man!
H
1995 cobra engine noise help
  • Holt2010
  • Nov 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 8, 2026
Holt2010
H
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
