E7TE or E6SE
  • Thread starter Thread starter Mafia Mustang
  • Start date Start date Jan 3, 2007
M
Mafia Mustang
111
Arizona
Jan 3, 2007
  • Jan 3, 2007
Which set of heads is better I recently had to switch from a 1990 block with E7TE heads to a 1986 Block With E6SE heads and is already broken in.
I have heard two diffrent storys on these engines one is that the E7TE's flow better and make more power. If this is true how much more power?
I have also heard the 1986 block was better because it had domed pistons or something and it makes better power that a newer block.
Just though i would ask thanks guys.:SNSign:
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Jan 3, 2007
  • Jan 3, 2007
the e7 heads are better because you can do more with them and they do flow better from the factory. the 86 5.0 had flat top pistons which is good for power but you cant put a big cam in it because of p/v issues
M
Mafia Mustang
111
Arizona
Jan 3, 2007
  • Jan 3, 2007
oh
Oh I put a E303 cam in there hope thats not to big.:SNSign:
txstang84
1,639
42
69
Tuscola, tx
Jan 3, 2007
  • Jan 3, 2007
might be close with the '86 flattops...the power difference is not much, but the E7's are a better head compared to the shrouded intake valves on the E6's..
ozanracing
172
  • Jan 3, 2007
You are not smart if you just slap a cam in without checking piston to valve clearance.
Especially with a e6 block. The e7 heads are worth 25hp over the e6 heads.
z2o_what
309
princeton, WV
Jan 3, 2007
  • Jan 3, 2007
kinda harsh... dont you think
V
v8only
2,378
22
49
Jan 3, 2007
  • Jan 3, 2007
there is a REAL good chance that cam will hit, you better check your clearances.
ALSO, the e7 heads do have a significant power advantage over the e6's, but will only bolt on 50% of the time, the other half they hit the pistons, and you're gauranteed to hit with that e cam.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
