Easiest way to install lowering springs
The rear is easy, and usually does not require a spring compressor at all.
On the front, an internal compressor works best. The stock springs are harder to get back in than lowering type springs. With the internal compressor, it is much easier. However, I have a KD tools internal compressor, and the spring arms and pivot is too large to come back out through the hole in the lower arm, so I took a couple strips of 1/2 in plate and a 5/8 threaded rod and made up a compressor.
Has worked a half dozen times for 10 years.
I have installed Ford lowering springs without the compressor, but it was a pita.
I just finished doing springs for the first time on a foxbody without a spring compressor. It is more of a pain in the ass than everyone makes it out to be. If you have a clean car with no rust, you will have an easier time. If you have rusted bolts everywhere, plan on having the car down for a little while. The quad shock to diff bolt is very hard to get off, but notice the nut here is welded on, so it will not spin.
Getting The bolts out of the front lower control arm wasnt to bad, but I noticed that lowering the arm with a jack, is not as easy as it sounds because of how carefull you must be, making sure to not let the front spring to pop out.
These are a few things I ran into that were a PITA, all in all it wasnt TOO bad, but it wasnt as easy as it sounded
I suppose now that I have all new hardware, I could do it faster, I really couldnt see the spring ever popping out that easily unless you were being a complete jackass, its held in there pretty tight, and took some wrenchin on my prybar to get it loose.
Good luck
Why would i have to remove the uppers and the quad shocks? We did my friends gt and got them in without removing those. IM using a spring compressor so i guess it should be easy.
i took out the quads to just give me more space. the rears you might need to heat the bolts up a bit to get loose, the fronts are easy, you just need 2 jack (makes it easier) and to take you tim. a prybar is you friend :)
The best compressor for the fronts has a plate for the top and a plate for the bottom and the threaded rod comes downward as you turn it through the hole in the A Arm. For the rears, if you undo the shocks and carefully lower 1 side at a time you can slip the springs right in place.
What kind of springs are you going with?
I have never needed a spring compressor when installing lowering springs.
For the rear you just put the car frame on jackstands and let the suspension come down. Then pull off the wheel and unbolt the lower bolt on your shock and unbolt and move out of the way your quad shock (if you are running them). Then just push down on the rear end from one side with your foot. The old spring should just fall right out. If not jack up the opposite side of the rear end to drop down the side you are working on and it will come right out. The new ones will be easier to put in because they are smaller.
For the front, put the front of the car on jackstands again so you can lower the suspension. Unbolt the wheel, unbolt the top bolt on your swaybar, and unbolt the 2 large bolts on the bottom of the strut and unbolt the brake caliper and tie it up out of the way. (Hint) Let the A-Arm down with the jack all the way until the strut bottoms out and holds the A-
Arm up, then jack up the A-Arm just slightly to releive the pressure from the spring. This should make getting the 2 bottom strut bolts out a lot easier as there should be no pressure on them now.
Once they are out then slowly lower the A-Arm all the way and move the jack out of the way to let the spring expand. It should amost be able to come out at this point. You may have to push down on the A-Arm with your foot a little to remove the spring.
The new lowering spring should just go in "WITHOUT" a spring compressor. Just put it in the A-Arm and raise it back into place with the jack. Once you put the 2 bolts from the bottom of the strut ina and tighten them up you can remove the jack. Then install the bolt and bushings back on your swaybar and install your brake caliper. Put your wheel back on then do the other side.
Then enjoy your new ride.
Good Luck.
Lowering springs
Just don't forget to check wheel alignment, after you lower the car you usually wind up with too much negative camber 2 degees or more. You can slot the strut mounting holes or get camber plates...I used Maximum Motorsports 2way plates and adjusted mine to: maximum positive caster, 3/4 degrees negative camber and 3/32" toe in. 1st I tried the slot method and car was squirrely because of a lack of positive caster, go the plate method. HTH :nice:
