Suspension Extremely Quick / Light Steering
Okie
Oklahoma
Greetings All, I just picked up an 89 GT for my son. I have noticed that the steering is extremely quick and very light. Is this normal for this particular type of vehicle? It has had a suspension kit and lowering springs installed (type unknown) There is no slop, and everything seems to be in proper working order. Is there a way to take some of the sensitivity out of it?
Don’t quote me but they are naturally light. I think the fox rack is a 20:1 ratio where as if you ‘upgrade’ to a newer sn95 rack they are 15:1 so you get a little heavier feel.
I’m currently in the process of doing this upgrade as I type. Using a GT rack out of a 2004 I believe.
Fox sport racks are 15:1. It's not uncommon for someone to accidentally swap in a 20:1 rack from a 4 cylinder car. Happens quite often because when you look up these cars in parts computers it still lists both racks for every model.
20:1 rack would be 3 turns lock to lock. A 15:1 rack would be about 2.5 turns lock to lock. Good way to try and tell which one you have.
Sn95 rack would be an upgrade. Still 15:1 but a lot better valving. 2004 GT/Cobra would be the rack to see out but you'll need other parts as well (hybrid rack adapter)
Reactions: gkomo
