Hey, just wonder what would be easier on a 97 gt. Drop the k-member and motor out through bottom or pull out through top. I have to take the k-member out either way to get to the header bolts.
........This is her b/f, and the cams being to big and causing ptv doesn't have anything to do with how good or bad I am at working on cars. Personally I think I think I did pretty d*mn good considering I am only 16 and did every bit of by myself. And after I cut valve reliefs in the pistons with a die grinder it ran awsome. Then it spun a bearing. Now I am putting a new motor in it, by my self. So I guess you shouldn't be raggin on me huh!!!!!!! Not tryin to sound cocky.Modular2v said:wow your 16 and doing all that???? i was doing tha when i was 15 haha.
TNstanggurl said:![]()
TNstanggurl said:And after I cut valve reliefs in the pistons with a die grinder it ran awsome.
well maybe so but that is how delk performance here in nashville told me to do it. You could see were the valves hit before so I used a air drinnel and a little cone shaped carbite bit and it worked fine for me. Then checked all my clearances and it worked fine. The old motor spun a bearing, thats why it is getting replaced, the cams would be goin in the new motor but we had to sell them to get it.billyfe390 said:I just cought that.
You do not fly cut pistons that way that is just half assed and retarded.
thats what happens when you have been working on a car all day and start rushing yourself. That mistake will never happen again, for D*MN sure.CanadaStang said:If you wouldn't have put one of the sprockets on backwards I'd be a lot more impressed.![]()
TNstanggurl said:thats what happens when you have been working on a car all day and start rushing yourself. That mistake will never happen again, for D*MN sure.
