easy tach light
corey796
85
i added a raptor tach light very easy here is what i did
running the wire down the door seal trim panels to a wire loom to the left of the clutch pedal under the hood its a tight fight but you can get your hand into the hole next to the master cylinder then i attached the green wire to the wire going to the coil that was not red. then pulling the bolt on the bracket in i striped the black wire and grounded it.
last the only key on hot, key off not hot wire i could find was to that egr sensor or what ever it is and its done i left the extra length of wire under the hood so i did not have wires getting in the pedals
the kit did not come with any screws (not that i would have used) i plan on getting some 3m double sided tape or Velcro to attached the light to the a-piller and i will be adding the fuse the kit called for but did not come with i have the fuse just not with at the time
its very cool
i hope this helps some body its the first mod i have done to this car and very easy
