Hey there. I have the frustrating and dreaded "94-95 GT ping". I have looked in the archives but can't find anything about whether or not the ECT is also the input for the OE temp gauge. My gauge always sits at about the "no" part of normal. No matter how hot it gets outside. The car does have to warm up for the gauge needle to move. I replaced the rad and coolant, this past Spring.
I have replaced the fuel filter, cleaned the MAF, replaced the ACT, checked timing (10 degrees, perfectly). I have also run the "Sea Foam" through the gas AND the intake. I guess that the ECT is next? What then?
I feel that the car should run on the recommended 87 octane, so that's what I run in it. I have tried several different gas stations to eleiminate "bad gas" as the problem. I don't hear it every time that the pedal is floored, just once in a while. Sometimes worse than others. I want to get this fixed, before I yank it apart to put the ported GT40's and Explorer intake on it.
TIA. Rob
TIA. Rob
