- Jun 14, 2007
- 514
- 284
- 93
Hey guys I have a question regarding the ecu ground. The previous owner relocated the battery to the trunk. My car has a wire tuck, so most wiring is in drivers side fender.
It appears that they cut the ground wire that went to the negative battery terminal.
So, can I pull the remaining wire out of the existing terminal and add a new 10ga wire and run it back to the battery? Or should I just use a new ring terminal and tie the two together?
I attached a picture, might be hard to see.
Also, what problems could I have by leaving it as is?
Thank you.
Thank you.
