Ecu!!
  • Thread starter Thread starter gooch06
  • Start date Start date May 27, 2005
G
gooch06
117
  • May 27, 2005
How do you tell if your ECC is no ggod??
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 28, 2005
  • May 28, 2005
The car doesn't run.
Computers are very tough and usually don't die. Most of the time there is a sensor or wiring problem that causes all the trouble.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
ponyboy19
1,640
May 28, 2005
  • May 28, 2005
jrichker
Thanks for the links.. Have you actually used either one of the scanners that you linked up? I know autozone and Advanced Auto Parts both have scanners, and neither will read either one of my mustangs codes 92gt and 95gt. Just wondering if these scanners would have the same problem as theirs does?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 28, 2005
  • May 28, 2005
ponyboy19 said:
jrichker
The paper clip works in the same manner as the more expensive scanners. It tells the computer to go into test mode and output the results on the tan wire. The tan wire drives the check engine light.
Wnen scanners (or the paper clip method) doesn't work, it is usually caused by bad wiring. Either the black/white wire that provides the test ground is bad or white/red wire is bad. On rare occasions, the signal ground trace inside the computer will burn off the PC board and render the self test functions inop. That usually causes a number of sensor inputs to go off scale as well.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
