Hi all , i have a 86 gt that i rebuilt back in march , its a mild 306 , and i did away with the efi and put on a carb . I had an odd holley given to me and i used it for a while but could never get it to run right , so i bought a used eddy 1405 and cannot get it to idle , when it drops bellow 1300 rpms it will die or idle will surge up and down and then die like it has a air leak , but i have checked and cannot find one , and the holley idled just fine , just didnt perform like i wanted , and seemed like it blew a power valve everytime i started it . I put a rebuild kit into the edelbrock , adjusted the floats , adjusted the idle mixture screws , checked for leaks , used a vacuum gauge it reads 15hg and and will jump back and forth up to 17 , wont hold steady , but the rpms arent holding steady either . I dont think the metering rods are bent , but i tried pulling them up while running and it seemed like it picked up im also going to put some different step up springs in it and maybe jets but i wouldnt think that it would cause that , and it seems to be ok being choked but when you open the choke it falls flat , above idle its great , has great throttle response and runs good so im kinda baffled , any help would be great , thanks . Andrew
View attachment 136631 View attachment 136633 View attachment 136635
