Edelbrock rpm 2 intake help
a_k
170
Saratoga NY
HEy everyone, most of the stuff I'm doing getting this motor in my car its my first time. I just was wondering if you guys could help me get this together I just needed help on what goes where because I didn't know if it mattered. Also I deleted my egr and air pump so I was wondering what I could just plug off.
These two holes right off to the side of the big hole.
I really don't remember what this goes to.
The two small holes here I think one goes to my fuel pressure regulator but i'm not sure of the other one.
Also on the lower intake there are 3 holes, two on the drivers side, one right up front in between the front 2 injectors and one in the back where it is flat near the pcv valve. There is also another hole right on the other side near the same spot. I'm just unsure of what can be plugged up and what goes where. I'm really pumped to get this thing running it's getting close:D
on the lower i beleive only one is unplugged, drivers front side hole.and you put your temperature sender in there. the rest are plugged of. correct me if im wrong, not sure on the top one
IIRC the ECT sensor is on the front passenger side of the lower, and the temp sender (for the gauge) is on the front driver's side. I think the back one has to be pluged though. i can't help you on the upper though, I don't recognize any of those holes.
1,2,4,5 are all plugged on mine
here are some pictures, if you have any questions just let me know
also with the egr out you can get a piece from wazee pulleys to cover the holes if you don't already have something for it.
