eec all figured out
  • Thread starter Thread starter whtnotch
  • Start date Start date Feb 8, 2008
W
whtnotch
123
Chicago
Feb 8, 2008
  • Feb 8, 2008
Ok I sumd it down to my ECU being the problem,and that being the reson the car wouldn't dump codes. I picked up a Brand new A9L car runs perfect also finally trew some codes.
Koeo
22
85-says canister purge trans axel problem?3/4 gear solenoid failure?
or ECA ada[tive "lean"limit reached in fuel control????
Koer
94-thermactor air system problem on right bank??or trans axle prob shift solenoid "ss1" circut failure??
44- problem with thermactor sir control
memory
22-manifold absolute press (map) sensor or barometric pressure(bp) sensor-signal voltageout of specifications or not at normal vaccum levels
Now how do I fix these?¿?
I know the manifold pressure sensor or BARO that on fire wall isthere but no vaccume running to it?can that be on problem? any help be appreciated
W
whtnotch
123
Chicago
Feb 8, 2008
  • Feb 8, 2008
bump
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Feb 9, 2008
  • Feb 9, 2008
well you can eliminate the 3/4 gear error and the other transaxle code definition and just worry about the other one because you have a 5 speed from what i looks like in your sig.
now for the other part of those codes......hook a vacuum line up the the map sensor and is your smog pump and all related tubing/valves/vacuum lines in place or are they ripped out like most of our cars?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 9, 2008
  • Feb 9, 2008
Code 22 MAP (vacuum) or BARO signal out of range. The MAP or BARO sensor is pretty much the same sensor for both Mass Air & Speed Density cars. The main difference is where it is connected. Mass Air cars vent it to the atmosphere, while Speed Density cars connect it to the intake manifold vacuum. Its purpose is to help set a baseline for the air/fuel mixture by sensing changes in barometric pressure. The MAP or BAP sensor puts out a 5 volt square wave that changes frequency with variations in atmospheric pressure. The base is 154 HZ at 29.92" of mercury - dry sunny day at sea level, about 68-72 degrees. You need an oscilloscope or frequency meter to measure it. There is no way you can use a common cheap voltmeter or DVM to accurately measure the output signal.
The MAP/BARO sensor is mounted on the firewall behind the upper manifold.
Baro or MAP test using frequency meter - run the test key on engine off. The noise from the ignition system will likely upset the frequency meter. I used a 10 x oscilloscope probe connected from the frequency meter to the MAP/BAP to reduce the jitter in the meter's readout.
If it is defective, your air/fuel ratio will be off and the car’s performance & emissions will suffer
Some basic checks you can make to be sure that the sensor is getting power & ground:
Note that all resistance tests must be done with the battery negative cable disconnected from the battery. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter.
Check the resistance between the black/white wire on the MAP/BARO sensor and then the black/white wire on the EGR and the same wire on the TPS. It should be less than 1 ohm. Next check the resistance between the black/white wire and the negative battery cable. It should be less than 1.5 ohm.
The following power on check requires you to turn the ignition switch to the Run position.
Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or EGR sensors. Use the black/white wire for the ground for the DVM.
Codes 44 & 94 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks. Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve. The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheelwell turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
See http://forums.stangnet.com/attachment.php?attachmentid=50636&d=1180923382 for a very nice drawing of the Thermactor Air System (smog pump) plumbing
If you have a catalytic converter H pipe, you need to fix these codes. If you don't, then don't worry about them
Code 85 - CANP solenoid - The Carbon Canister solenoid is inoperative. Check vacuum lines for leaks and cracks. Check electrical wiring for loose connections, damaged wiring and insulation. Check solenoid valve operation by grounding the gray/yellow wire to the solenoid and blowing through it.
The computer provides the ground for the solenoid. The red wire to the solenoid is always energized any time the ignition switch is in the run position.
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel.
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
W
whtnotch
123
Chicago
Feb 9, 2008
  • Feb 9, 2008
so where should I hook the Baro up too. There is no smog,but there is all the vaccume stuff on the passanger side.are theses serious codes could they hurt my cars performance??
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 9, 2008
  • Feb 9, 2008
The Map/Baro sensor does not connect to vacuum on mass air cars. It vents to the open air. The code 22 will hurt performance and economy.
The code 44/94 can be ignored if you don't have a cat converter H pipe.
The code 85 if ignored will make you car stnk like gas, but won't hurt perforamce. Fuel economy may suffer a bit. See the warning about parking in a closed garage if you have a gas water heater.
W
whtnotch
123
Chicago
Feb 9, 2008
  • Feb 9, 2008
how do i fix 22?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 9, 2008
  • Feb 9, 2008
whtnotch said:
how do i fix 22?
Go back and read the code 22 test path. Do all of the tests that you can do with the tools and equipment that you have access to.
IF after you have done all of the testing you can do, and have not found anything wrong, replace the Map sensor. Do not replace it without verifying the wiring, ground or voltages. Map sensors are expensive and throwing money at it without being sure it is defective can be very expensive and discouraging.
W
whtnotch
123
Chicago
Feb 10, 2008
  • Feb 10, 2008
Well after doing some extensive tests (knowledge courtesy of Jrichker) Ifound that the Baro/Map was the problem car runs like a champ after changing.No vibration,better throttle response,just sounds all around smoother also bumpd timing to 16* took it well with no pinging.While I was there I checked and adjusted the tps for correct operation.
:SNSign: Kicks A$$
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
'03 GT fresh rebuild, engine severely cutting out on hard acceleration
  • Bowtierebel
  • Sep 1, 2018
7K
1996 - 2004 SN95 Mustang -General/Talk- Sep 25, 2018
Bowtierebel
J
5.0 Ho Swapped Comet Lean Backfire Issue
  • jas280z
  • Aug 18, 2017
9K
Fox 5.0 Mustang Tech Aug 21, 2017
jas280z
J
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
