EEC IV bare min....
oupunk
long story short......putting EFI on a 60s 289.....the actual unit in hand is a DG1 -SD/SFI - ala 87-t-bird(it's actually out of a cougar)......so cut to the chase, what's the bare amount of sensors that are required for this to work propperly?......obviously, i could care less about any emmissions parts, but do they HAVE to be there?.....what about VSS?...and as a side note, this unit does not even have a wire in the correct pins for vss.
if anyone needs any other info, or has any suggestions...or sees a major flaw in the plan....let me know.
thanks guys!
EDIT: oh yeah...before anyone asks...there is literally NO room in the engine bay for a MAF setup....so it's staying SD/MAP.
SD is nice for the older stuff IMHO. If you ever need a MAF-set-up, you might be able to toss it in the fender.
VSS should not be requisite. I'll start a list of what I can think of real quick (others will expand upon it). MAP, ECT, ACT, PIP, TPS, And O2's are nice. It seems to me that you'd need an IAC and TFI ignition too.
Good luck with the project.
Why speed density? That computer is a Speed density computer. You will need all the sensors that for sure but you wont need a MAF meter.
Allen
just to clarify....this car will not use MAF, unless it is absolutely neccessary to switch for performance reasons...so no one needs to say "SD sucks!"....or "use an A9L!"....however, if someone would like to chime in that unit ABC123 is better than the DG1, i'm all ears...as long as it's still SD.
thanks!
I disagree that you will need all the sensors. For instance, if you are not running emissions equipment, you will not need those items.
The 5 spd processor for an 88 GT with SD (49 state model) is a DA1.
thanks!
You are going to have to duct cold air into the throttle body using some sort of flexible duct system. Therefore a MAF is just a splice into the ductwork feeding the engine.
All of the EFI conversion harness assemblies I haves seen are for Mass Air computers. Unless you are really good with wiring, I would recommend that you use one of the EFI conversion harness kits. All of the Speed Density Mustangs (86-88) have a fair amount of odd wires in the harness for things like the A/C compressor, water temp and oil pressure gauges.
Mass Air conversion harness sources:
See http://www.google.com/search?hl=en&rls=com.microsoft:en-us&q=M-12071-A50*&btnG=Search for sources for the FMS M-12071-A5 one piece EFI conversion harness.
See http://rjminjectiontech.com/?p=3 for a Mass air EFI conversion harness specifically designed to convert classic Mustangs to EFI.
See http://rjminjectiontech.com/harness_manual.pdf for the manual for the above harness. You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
I highly recommned that you read the above manual even if you don't buy their product.
Welcom to the board!
I think you are over-estimating how much space a MAF setup uses...
But that aside...
Anything that is not related to emissions, should be used. If you have a VSS input at the ecu, then hook it up.
If you don't, it will only cause you headaches later on.
Do you have the correct wire harness for that ecu?
Sounds like a fun project,
jason
that's roughly what i'm working with here....as you can see from the pic, not much room....with the 4bl on it right now, there's roughly 2" from the top of the carb to the hood....attaching anything other than a really thin filter to the throttle body would be near impossible.
i suppose anything is possible, but the harness and ECU in question did come out of the same(totally stock) car...so i don't have any reason to believe they're mismatched.
thanks for the input guys, keep it coming!
If this is an Alpine project (I'd be surprised if it was a Tiger given the value of 'em), this is an awesome project. You really are space challenged between the wells on those things.
I'm not real smart but I'd wonder how an EFI intake is going to fit vs a carbed set-up. A 94-95 or Thunderbird intake might be required (as is common on Cobra kits) to make it fit.
why yes, it is actually a tiger(the owner does have two alpines awaiting 2.8 V6 packages though....) :)
if you'll note on the picture how far the valve covers go back under the cowl...aside from the height problem, the usual "5.0" style runner/log intake will not fit...otherwise we could have just wanked the 289 in favor of a crate MAF 302 and been done with it...but what's the fun in that anyway....
the final setup will be..(back to the pic again)...similar lower intake with provisions for injectors, sensors, etc topped off with a 4bl TB and filter...other than the dist. fuel rails and misc wiring, it'll end up alot like the pic...and run by a SD/SFI ECU minus all the emissions junk and anything else that really isn't needed...
here's the victim :nice:
