EEC Test connector
gooch06 said:
Thanks I found it. Is there supposed to be power to the terminals?
No. They are all either signal connections that are connected to ground to activate them or a test ground connection (Black/white wire) for testing purposes.
Jumpering the black/white & tan/lt greeen wire together should trigger the fuel pump relay and and make the fuel pump run if all the rest of the fuel pump circuit is OK.
