EFI conversion questions
  • Thread starter Thread starter Decurion
  • Start date Start date Oct 21, 2009
Decurion
353
Livonia, MI
Oct 21, 2009
  • Oct 21, 2009
Im sure Ill be updating this post with a flurry of questions regarding my swap at some point, but for now just one question. Is the wiring harness and computer the same between a Mark 7 and Mustang of the same year (1990)? If so, what do I need? Im thinking basically locate the computer and get the harness that comes from it. Theres a 1990 Mk7 someone traded in the cash for clunkers program in my local self serve junk yard, and it looks to be in pretty good shape and complete. I forgot to see if it was MAF or SD. I already have a gt40 intake, 65mm TB, and 24lb injectors. Should I grab the throttle and trans linkage while Im there too, since Ill be using an AOD eventually?
R
Ryans67
238
Sacramento Ca
Oct 21, 2009
  • Oct 21, 2009
When I did mine I took everything. Linkage, every wire that contacted the engine or computer. One other thing was the gas pedal. I traded pedals to make it easier to adapt the linkage. I figured it was better to have it all now, then to need it later. Also, I took the drive line so I could cut two to make one with the correct input shaft. Thats all I can think of now.
R
Red5oh
377
DFW, Texas
Oct 22, 2009
  • Oct 22, 2009
What model is your car? I have an EFI pedal for our cars, but it is for a 67-8 NON AC car... I ended using the 89 pedal with some mods since mine does have the factory AC
P
phutch11
328
Oct 22, 2009
  • Oct 22, 2009
Wiring is not the same. I believe all Mark 7s were SD.
Having done the swap, I'm not a big fan if your only goal is power - there are much easier ways.
But, if you must, then grab all the wiring you can, every sensor, every connector, everything. Grab the gas pedal and the fuel cutoff switch too. Grab all the front dress, pulleys, AC, PS, everything.
Much better to have it and not need it then the other way around.
Good luck....
Posted via Mobile Device
mr_woodster
1,314
Riverside, CA
Oct 24, 2009
  • Oct 24, 2009
Correct , the wiring would be different from the mustang /mark . Also the early computers (minus cobra) are tuned for 19lb (orange/yellowish) injectors.
The gas pedal is pretty simple, it just depends on what setup you want to go with. I myself used the Lokar (spelling?) cable pull pedal. It was easy and took about an hour to install.
Novice needs advice on an optimal engine/computer setup
  • 02 281 GT
  • Mar 21, 2021
  • Digital Self-tuning Forum
Digital Self-tuning Forum Apr 5, 2021
a91what
Fuel 1995 stock Mustang EFI vs aftermarket TBI or Edelbrock injection? Jag Project Car
  • stasha
  • Mar 16, 2020
7K
Fox 5.0 Mustang Tech Mar 16, 2020
a91what
D
SN95 95 Auto V6 To Manual Obd2 5.0 Complete
  • DieselDan
  • Jun 23, 2015
7K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2015
02 281 GT
Fuel System Questions (efi Conversion)
  • Decurion
  • Jul 29, 2012
Classic Mustang Specific Tech Nov 23, 2012
iskwezm
P
EFI Conversion Experience (long)
  • PhilJustPhil
  • Apr 29, 2012
2K
Classic Mustang Specific Tech Apr 29, 2012
iskwezm
