Efi Conversion!!!
  • Thread starter Thread starter 67staaang
  • Start date Start date May 4, 2005
67staaang
132
  • May 4, 2005
im trying to find out lots of info on EFI conversions before i really get into it. so please help with info on what to do and how. i get 97% of the conversion but the one thing i dont get is the fuel lines? how do i make a return fuel line? what kind of fuel pump would i have to purchase? and also i just had bought a MSD PRO billet dist. would i have to purchase another dist. when converting to EFI?? thanks!!
R
ron67fb
1,117
SF Bay area, CA
May 4, 2005
  • May 4, 2005
Use your stock fuel line as a return line, and make a new pressure line.
Distributor depends on the EFI system used. Have you decided which one? Factory? Aftermarket? Speed density? MAF? I don't think you've reached 97% yet.
Rollinns
41
Missouri
May 5, 2005
  • May 5, 2005
I also used the stock line as a return line and ran it to a fitting screwed into the drain plug hole. For the high pressure line I pulled from the tank to an external frame mounted high pressure pump (mid 80's ford truck) to a filter, then to 5/16 lines made from brake lines. Use foil to make a pattern then bend it and install it.
I used fuel hose rated for high pressures to connect the brake lines.
I recommend getting a donor car to make sure you get all the little brackets and such.
Glen's 1965 5.0
477
Tomball,Texas
May 5, 2005
  • May 5, 2005
EFI info
I detailed my learning experience on my EFI conversion found here: http://users.ev1.net/~gbuzek/Engine.htm
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
