EFI conversion?
  • Thread starter Thread starter TrickFlowd
  • Start date Start date Oct 23, 2007
TrickFlowd
240
Sayre, PA
Oct 23, 2007
  • Oct 23, 2007
I know this isn't a Fox body issue...but I'm not sure where to get this information from.
My dad has a 65 F100 pickup, which is going to be a show/nice day driver only. We have been working on this truck for about 3 years now, and its close to being done. Everything is new. Mustang II front suspension conversion, 00 Explorer rear disc conversion, everything is shaved, etc, etc. But, we have come to the conclusion, in order to win shows, EFI conversion is needed, and would benefit the overall performance and look of the truck. So....
What parts do we need? The motor in the truck now is from an 87 5.0 Mustang, but is carbed. I know the basic parts that we are gonna need (dizzy, upper/lower manifolds, sensors, computer, fuel pump.
What wiring do we need to do this conversion?
Any help would be greatly appreciated! Thanks in advance!
85ragtop
BTW, I like dudes.
475
123
NC
Oct 23, 2007
  • Oct 23, 2007
Thread moved.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Oct 23, 2007
  • Oct 23, 2007
its going to be very involved. more than just a fuel pump. our cars are a returned fuel style system and i would not advise running a piece of rubber fuel line back to the tank. if you are going to do it do it right and have a new set of suply lines and retuen lines bent for it. and you where pretty much dead on, on everything else.
and alls you should need is the main engine harness and the computer. just pull it all from a donor car. if you try to piece it together its gonna get way to confusing.
samickguy15
404
Delavan, IL
Oct 24, 2007
  • Oct 24, 2007
I would suggest getting a truck or van harness as you'll probably be able to get one easier/cheaper. It also offers convenient through fire-wall mounting where the plug part of the ECU actually sticks into the engine bay allowing for sort of a quick disconnect for motor removal. Not sure what the truck weighs, but if you want to stay truck, you could go with a stock truck intake or look at the Edelbrock truck intake.
And if all else fails, get a Painless brand Ford EFI harness.
TrickFlowd
240
Sayre, PA
Oct 24, 2007
  • Oct 24, 2007
So what actually supplies power to the ECU? As far as fuel lines, I'm sure we could handle running braided lines or somethin.
So find a van or truck with a 5.0L? What trucks came with that motor?
tbovee
129
Fredericksburg Va
Oct 24, 2007
  • Oct 24, 2007
If I remember correctly you really only need a couple of wires in the harness to fire an efi. you need power to the ecc relay, start and run wires, good grounds for various places, wiring of the fuel pump, a blue wire to the solenoid ect. I wired my O2 sensors via a relay, and a few others. Get a complete engine harness with computer and study these diagrams. Check a couple of the other forums. theres a couple of good write ups out there, but I don't where.
I did mine with a couple of these diagrams.
http://www.autozone.com/az/cds/en_us/0900823d/80/19/59/5a/0900823d8019595a/repairInfoPages.htm
http://www.veryuseful.com/mustang/tech/engine/
TrickFlowd
240
Sayre, PA
Oct 24, 2007
  • Oct 24, 2007
What about dash wiring? Does all of the dash, lights, gauges etc, run to the ecu? Or is that a seperate harness? We plan to head to the junkyard this coming weekend to get a harness and computer.
What about EGR and all of the emission sensors? EGR blockoff plate and custom computer chip to get rid of it? We want to do away with all that crap, since emissions on a 65' is not possible.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 25, 2007
  • Oct 25, 2007
For an EFI conversion harness see http://fordfuelinjection.com/index.php?p=21 they have everything you need.
Or see http://www.fordracingparts.com/parts/category.asp?catID=76&catdesc=Wiring.
samickguy15
404
Delavan, IL
Oct 25, 2007
  • Oct 25, 2007
As tbovee said, there's only a few wires that need to be run out from the harness. They generally pick up power at a main fuse/relay box in the engine bay. Again, as he said, you need good grounds to the block and chasis. If you find a good harness or donor car, you should be able to find the grounds and note their locations. Most people run extra grounds just for good measure.
Fuel lines - you could either go braided or even get standard brake/fuel line for the cheap route. You could also run the aluminum stuff too. Get yourself a Jegs and Summit Racing. They have various options for plumbing.
I would look for an 87+ truck or van. If you could find an Explorer, that would be even better as you could get the intake and heads or even the whole motor if you want. It would be a good platform to start with if you can get it cheap enough. I got a whole motor with harness for $260, but I've read that most people end up paying around $600 for a good Explorer motor.
The early trucks/vans are going to be speed density which can give you a cleaner install, but is not as good if you add cam, intake, etc. The later ones 91?+ have MAF and would be a better option.
As far as dash stuff, there are a few sensors that tie into the dash, but not enought to worry about. I usually just cut all of the pigtails for the stuff I can't unplug or pull out easily, which is usually just the few that go into the dash. Some of the trucks/vans have the headlight harness integrated into the engine harness, which is a PITA. Anyways, just cut all the pigtails for the dash harness and you may or may not use them later. You could always run other gauges or sensors for temp, oil, tach, volt, etc.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Oct 25, 2007
#10
  • Oct 25, 2007
  • #10
You can a complete harness from Painless Wiring for a 5.0L fuel injected engine. It includes all new connectors and wiring but is somewhat expensive. I think I paid around $400 for mine. I had a donor harness from another Mustang but it had been cut up and needed a lot of work. It started giving me intermittent problems. So the cost of the Painless wiring was well worth it for me. As far as the ECM, you'll probably want to get an A9L or A9P module. You could then get a Tweecer to disable the emissions equipment and to tune the engine how you want. Its more expensive but you could get a whole stand alone Engine Management System like F.A.S.T. It all depends on how much you want to spend and how much you want to control the engine. Good Luck!
TrickFlowd
240
Sayre, PA
Oct 25, 2007
#11
  • Oct 25, 2007
  • #11
Thanks alot guys. This really helps ALOT!
The Tweecer? Where do I find them? I'm interested in one for my stang also!
bullitstang1313
713
Oct 26, 2007
#12
  • Oct 26, 2007
  • #12
You can't buy it directly from the website anymore, but I think it has links for authorized resellers. Here
You want to make sure you get the Tweecer RT that way you can log data as well. It makes it much easier to tune.
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
