EFI Fuse location?
JimGT
27
About to do a compression test. Part store said to remove EFI relay/fuse. I've read several posts looking for the answer to which fuse this would be and can't find anything about the EFI fuse. Any help??? :shrug:
Disconnect the inertia cut off switch in the trunk. It is behind the driver side tail light on the inside of the trunk under the paneling and has a red button on top. Use a small screwdriver to gently lift off the connector and then pull it off.
Oh yeah.... and after you disconnect the fuel inertia switch run the car at idle until it stalls and dies. This way you know that all fuel in the system has been used up and the pump is not sending any more.
