R ray95 New Member Aug 4, 2002 37 0 0 mass May 17, 2004 #1 May 17, 2004 #1 Do fuel injectors spray sequentially or all at the same time? Thanks
ECU5.0 Banned Jan 10, 2004 1,803 1 0 raleigh, nc May 17, 2004 #2 May 17, 2004 #2 they spray only when the computer tells them too...which is right when the valve starts to open
R ray95 New Member Aug 4, 2002 37 0 0 mass May 17, 2004 #3 May 17, 2004 #3 thanks for the info. I am putting a 88 ho into a f-150 and I am not sure how to handle the injectors with the different firing order.
S strtracer442 New Member Dec 12, 2003 175 0 0 Roseville,MI May 17, 2004 #4 May 17, 2004 #4 You'll have to use the computer and the firing order from the 88 HO, or you have to change the camshaft.
S seijirou Founding Member Aug 15, 2002 2,417 4 48 DFW Nov 28, 2006 #6 Nov 28, 2006 #6 THe mustang motors are fired sequentially, or one at a time. The truck motors are 2 bank batch fired, meaning 4 injectors fire at the same time. You should not have any issues with using batch fire on the HO motor.
