so, here are some pics of parts i pulled off an 87 GT today. I'm wondering what else, if anything, i should yank from it. yes i will convert it to a MAF set up.
Depending on what model Mustang you are putting this in, you may need to swap out your gas pedal. If so, that would be needed along with the throttle cable.
Did you get the O2 sensor harness, I couldn't tell in the pic.
Did you get all the relays: fuel pump, EEC power, and A/C WOT cut off relay
The fuel pump relay is usually under the seat, get it. Wire the inertia switch in before the relay so the switch can cut off power to the relay in the event of an accident.
