EFI Swap Sensors not needed
  • Thread starter Thread starter ks65stang
  • Start date Start date Dec 9, 2005
K
ks65stang
184
Kansas City Metro, Lenexa
Dec 9, 2005
  • Dec 9, 2005
OK My main harness and computer came in and everything looks well. I cleaned it up and started marking connectors. I know where all will go except what to do with:
1. Barometric Pressure Sensor (is this needed, can it be bypassed?)
2. and ERG connectors. I dont want to install an EGR system on my 65, how can I baypass this?
If anyone has any suggestions where I'd be better off finding these answers, please post. Im doingmost of my research on fordfuelinjection.com Thanks!
R
Red5oh
377
DFW, Texas
Dec 9, 2005
  • Dec 9, 2005
You will need the BAP sensor. It is typically located behind the intake on the firewall.
As for the egr, you can get the egr simulator and solenoid eliminator from www.ronmorrisperformance.com I also got the canister purge eliminator and one more... they are just simply (from what I remember 75 ohm, 3W resistors) but he give you the parallel connectors and tells you which wires to remove. His support is worth every penny.
68rustang
1,537
Cleveland, OH
Dec 10, 2005
  • Dec 10, 2005
Everything you need to know is online for FREE at www.fordfuelinjection.com.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 10, 2005
  • Dec 10, 2005
Another option is to find someone with a twEECer to shut them off inside the ECU.
86T-Top
553
Dublin, PA
Dec 10, 2005
  • Dec 10, 2005
If you do not install the EGR system, you need to disable it with either a tunner such as a TwEECer or with a chip. The reason you need to disable the EGR system is because the computer leans out the fuel mixture during certain driving conditions and uses the gases from the EGR system to compensate for the lean condition made by the computer. So if you remove the EGR system w/o disabling it in the computer, your computer will lean out the fuel mixture, but there will be no EGR system to richen it back up, causing a lean condition.
Do a search in the 5.0 section of this forum for more options on removing the EGR system.
Mario
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 21, 2026
Loose connection near the back of the alternator wiring harness
  • 1996 Stang GT
  • Sep 5, 2025
1996 Stang GT
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
