EFI theory question
enyawix
507
The stock EFI setup on a 5.0 HO
is 55mm MAF and 19lbs/hr injectors
55/19 = 2.89
or 2.89mm MAF : 1lbs/hr
Three inch pipe = 76.2mm
76.2 / 2.89 = 26.32
So will 76.2mm MAF housing and 26lbs/hr injectors keep the same air : injector ratio the stock MAF is setup for?
No, the math is inaccurate.
Think of it this way. Draw a circle with a 4 inch diameter.
Now draw two circles with 2 inch diamteres inside of that 4 inch circle.
It becomes painfully obvious how much surface area you are missing.
You have the right idea, but you need to fix your math.
Another way to go is to change the ratio of the sampling tube size to the size of the inlet.
A larger sampling tube will make you richer, smaller will make you leaner.
How it works:
The MAF sensors and MAF bodies are calibrated together as a unit. Type A sensor works with Type A bodies. The bodies and sensors are not necessarily calibrated together to create a precision matched pair.
The output voltage of the MAF is a function of the air flowing through it. The MAF itself does not know about injector sizes, nor does it care. All it sees is that an increase in airflow means a corresponding increase of MAF output voltage. Altering the design of the MAF body can alter the flow past the sensor.
The OEM Ford system was designed to use the internal calibration of the computer tables to match the voltage output of the MAF to a calculated injector pulse on time. The injector table uses only one size injector in its calculations. This is a much more accurate means of determining the engine’s fuel requirements.
What aftermarket MAF’s do is try to fool the computer by either changing the amount of airflow over the stock electronics or by altering the sensor itself. The goal for both methods is to change the output voltage of the MAF so the computer calculates new data that is used to vary the pulse width sent to the injectors.
